Results 1 to 4 of 4
    Jr. Mechanic johnsstart is a glorious beacon of light
    Jan 2009
    Angry 95 gmc sonoma 2.2 5 spd "help" if you can
    i have a 95 gmc sonoma its a stick when i get to about 40 in 4th gear it starts to make a vibrating sound with small shake i have replaced all plugs wires one coil pack still had same prob then alt went bad replaced that and new battery still had same issues then i noticed fuel gauge jumping alot so i figured fuel filter might be clogged so i replaced that and now i am still having same probloms shaking and vibrating at 40 to 50 and fuel gauge is still jumping not sure what to check next 1st through 3rd all shift fine and i dont hear anynoise so dont think its the tranny any help would be greatly app.
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Balancing on tires could be off, also if your rotors are warped bad enough you can feel it, your drive shaft could be off balance too. Can you feel it more in your foot on the gas or brake pedal, your butt or your hands on the wheel
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    I agree with the tire balance issue. It sounds like a harmonic vibration, some moving part or parts are vibrating after a certain speed or rpm has been hit. Start with the tires then maybe take a look at the fly wheel and axle. I'm not convinced that the fuel gauge is a factor with this issue.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
    Jan 2009
    Thanks guys i will be looking into those things suggested this weekend and ill update
Similar Threads
  1. Stock "P" rims safe with "LT" tire pressure?
    By xycarp in forum Wheels & Tires
    Last Post: 05-31-2010, 10:38 AM
  2. What does "detonation" sound like? Engine "knock"?
    By Big6ft6 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-04-2009, 02:04 PM
  3. Replies: 0
    Last Post: 06-21-2008, 01:30 PM
  4. Replies: 0
    Last Post: 07-24-2007, 01:30 PM
  5. "Monster Mash" Singer Bobby "Boris" Pickett Dies At 69
    By Cableguy in forum The Coffee Shop
    Last Post: 04-27-2007, 11:47 PM
