Results 1 to 3 of 3
    Master Mechanic goldie is a splendid one to behold
    Aug 2008
    Chesterton, IN
    5 Post(s)
    1 Thread(s)
    Default Intake Air Temp Relocater?
    I ran across an air intake relocater accessory on the Jet performance site. It is supposed to increase power by allowing the computer to sense cooler air. Does anyone know if this will also increase mileage. I've written to Jet on another matter but haven't heard from them so I now need outside opiniions.
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    I don't know about that one. I'd get Jet's response in writing. As it stands, the cooler the air the better the power outpu is. That doesn't sound too good to me.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
    Jr. Engineer mjalstad is a glorious beacon of light
    Jan 2009
    Rochester, MN
    I don't like the idea of that. It is tricking the computer to increase timing which would probably be fine during cruising as you wouldn't see any knock retard and better MPG, but whenever the engine has a load on it such as going up a hill or at WOT you will probably be seeing a lot of knock retard which is not good. Basically anything that is used to trick your computer is something that I would stay away from.
    99 Silverado Z71 4.8
    2" Suspension lift (Add-a-leafs and leveling keys)
    Long tube headers with 3" offroad Y-Pipe
    Volant Cold Air Intake with Ram Air Intake Tube
    Jet Mass Air Flow Sensor
    Diablosport Predator Tuner
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
    35" Yokohama M/T's
    K&N Intake
    Airraid Throttle Body Spacer
    Hypertech Programmer
    Dual Flowmasters
Similar Threads
  1. Temp???
    By TJ smith in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-24-2011, 10:12 AM
  2. outside temp on DIC
    By Earl27 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 07-20-2009, 09:55 AM
  3. what temp?
    By warsey in forum Chevy Blazer Forum (GMC Jimmy)
    Last Post: 06-23-2009, 08:59 PM
  4. Temp
    Last Post: 05-13-2009, 04:02 PM
  5. tranny temp?
    By 84Condor in forum Powertrain
    Last Post: 01-24-2009, 07:36 PM
