I want to install a CB radio in my truck ,the Cobra Classic 29LTD, and I am not sure how to wire it properly and dont want to blow a fuse or over load the circuits. Anybody have some ideas.
09 Silverado single cab 4.8
20% tint
6000k hids
cherry bomb extreme dumped
smoked tailights
3inch lift
black bowties
train horns
Heres 2 ways to run your CB:
Keyed, only works when the ignition key is on.
Parts needed:
Relay
Black 12, 14, or 16 ga. wire
Red 12, 14, or 16 ga. wire
3 Blade connectors
1 Lg ring connector
1 small ring connector
1 tap splice
2 Butt end connectors
Locate semi-dry place to mount the relay on the firewall.
Run pwr wire + (red) from the battery to the "Batt" terminal on the relay, use a lg ring connector at the battery and a blade connector at the relay.
Run pwr wire + (red) from "Acc" terminal on the relay to the red + wire on the CB, you'll have to route the wire through an existing grommet on the firewal, use a blade connector on the relay and a butt end connector on the two wires.
Locate a wire from the fuse box that connects to an accessory that only works when the key is on, for example the windshield wipers, use a tap splice to connect a pwr + (red) wire through a grommet on the firewall and connect to the "sig" terminal on the relay with a blade connector.
If there isnt a good ground spot near the radio mounting place use a butt end connector to splice a longer piece of grnd - (blk) wire on, use a smal ring connector to attach the ground to a suitable ground point inside the cab (any screw running though metal should suffice.
Full time hot, works all the time no matter what position the key is in.
Parts needed:
1 lg ring connector
1 in-line fuse
2 butt end connectors
Run a pwr + (red) wire from the battery through an existing grommet on the firewall to the radio, between the radio wire and the new power wire connect the in line fuse using a butt end connector at each splice (the radio may have a fuse already but this redundancy wont hurt).
If needed splice in extra grnd - (blk) wire and connect to a suitable ground under the dash.
Sorry if this sounds simplified but I dont know your level of electrical experience.
I recommend the keyed method because if you forget and leave the radio in the full hot method you could kill the battery.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
Thanks I am not that experienced but this will help me alot.
20% tint
6000k hids
smoked tailights
3inch lift
black bowties
train horns
Where are you mounting the radio? I have the center consuel that doesn't give me any room on the floor board. I saw a picture of a radio installed under the arm rest of the consuel. It looked like a good idea. And there is a power out let already installed there.
Trevor - Huntington Beach, CA
2007 GMC 2500 4X4
its not hard at all run a fused power wire from pos on your bat and ground the other wire black to a metal ground near your cb thats it.
be all thats ends all
Bookmarks
