Results 1 to 10 of 12
    Default 02 Silverado starting/ running problems
    Hello all. I have a 02 Silverado 5.3L that has a terrible time starting in cold to freezing weather. On very cold nights the battery will drain almost completely with all accessories unplugged. I will jump the truck and it still may take up to 3-4 times cranking to get it to turn over. When it does, it stumbles and I need to give it gas to keep it going. Once I am going 1 of 2 things happen until the truck gets warm. 1: At a stop light the voltmeter drops below 10V and the engine stalls. OR 2: The engine idles very high especially in gear and makes it hard to stop because its pulling. I have replaced the battery and the altenator and still have these problems. I am assuming that I have a drain somewhere causing the battery to drain overnight but this does not explain the other problems. Sorry so long... any help is appreciated. Thanks!
    I would have the system tested, they can do a pretty good job pinpointing it, also check all the lines and make sue they arent corroded, even a little bit of corrosion on the starter wire will make it seem like its the battery, my sunbird did this alot and it took me three batteries to finally figure out the starter cable was correded at the starter, that was a lot of wasted beer money in college
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Thanks i will check the starter wire. By the way... this problem fried an Optima red top battery. Brought it back to Advanced and they tested it. Apparently Optimas are not known for frying on their own.
    Wow, thats not good, or cheap!
    checked all suggestions. problem is still there. HELP!
    Master Mechanic
    Oct 2008
    Brandon, FLA
    First, where are you locate at? Does the truck park in doors? Has this started since adding the Optima battery? Any other features added before the problem? Because addressing the charging issue first will
    help maybe to correct your other issues. What does the turck do when it's warm, or did it do?
    Jeff
    JMoney02
    Hey thanks for the reply. Sorry I've been away. The truck is in New Hampshire. Stored outside. This problem has happened with 2 separate Optimas. I have added nothing before this started. Only thing different was that the truck sat idle for 6+ months while I was deployed. Came back and the problem was there. Shorted an optima. Thought it was the battery and replaced (this was August). Had no real problems until the weather got cold again. It seems to run a bit better when warm (and warmer temps) but there still is a problem. Thanks again.
    Im thinking it could be the coolant temp sensor with the weird idle but that doesnt explain the dead battery.
    Double check all your wiring. Rats or something could have chewed the wire harness.
    The starter itself could be the reason for draining the battery if it wasn't started while sitting. And like was also suggested rats or mice could have got in and chewed on some of the wires, some are still hot even though the ignition is turned off. As for the ruff running and high idle at times that could be the Idle Air Control (IAC) valve, on a fuel injected engine this basically works a little like a choke would on a carb engine. and it is realitvely cheap, I replaced the one on my wifes Beretta for about $25.
    Quote Originally Posted by jlsparky7 View Post
    This happened to a 2004 Grand Prix GTP I had. They were living under the engine cover and chewed the engine wiring harness.
    Current Daily Driver:
    2003 Chevrolet Silverado 1500 - 4WD - 4.8L V8 - True Dual Exhaust Setup, Cat Delete, Cherry Bomb Glass Packs
  1. Starting Problems, '01 Silverado 2500
    By loppy crimp in forum General Chevy & GM Tech Questions
    Last: 10-03-2010, 11:01 AM
  2. troubles with a 98 diesel motor starting/running
    By renegaderider in forum GM Powertrain
    Last: 04-26-2010, 08:17 AM
  3. starting problems
    By Samuelg35 in forum General Chevy & GM Tech Questions
    Last: 01-21-2010, 02:44 AM
  4. Better starting & less problems!
    By FireRed in forum General Chevy & GM Tech Questions
    Last: 05-22-2008, 03:59 PM
  5. 99 silverado problems starting
    By 99silverado99 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-16-2008, 04:44 AM
