Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Sr. Apprentice jmutto is a glorious beacon of light
    Dec 2008
    Washington State
    Default Mirror Compatibility
    Hey everyone. I have a '04 Silerado 1500 Extended cab and have an opportunity to buy side mirrors that are heated and have the integrated turn signals. The parts list show them as '04 replacements, but my truck currently does not have the heaters or signals. Is the wiring for those features already present in the truck or am I going to have to run new wires if I want to do this upgrade?
    Thanks!
    "Sometimes, a little brain damage helps" - George Carlin
    2004 Chevy Silverado 1500 Extended Cab "Northwest Edition"
    Volant CAI
    Optima red top
    Westin chrome side steps
    Leer 100XL cap
    Line-x bed liner
    Cat back
    Panasonic DVD headunit
    Alpine amp & sub
    Garmin Nuvi 255 GPS
    Viper 900 alarm with remote start
    ScanGauge II
    Sirius Stratus 6 satellite radio
    BetterBuilt fender well box
    Jr. Mechanic johnsstart is a glorious beacon of light
    Jan 2009
    Quote Originally Posted by jmutto View Post
    Thanks!
    Good question i have 06 1500 crew cab wanting to do same, anyone knoW compatability for these
    Jr. Mechanic 05azsilver is a glorious beacon of light
    Mar 2007
    Chandler, AZ
    It may be prewired for those mirrors but you may have to buy the wiring harness. You can check the following link and see what is says.
    http://www.gmupfitter.com/publicat/2...lectric_CK.pdf
    Chris
    2005 Silverado - 4.3L, 5spd Manual, K&N Drop in Filter, Modded Air box
    Kenwood KDC-MP732 Head Unit, Pioneer 760W Amp, 2x 10" MTX Thunder 6000 subs, Uniden PC68XL CB/PA
    2004 Cavalier - 2.2L Auto
    Bone Stock
    1977 Toyota Celica GT - 20R (2.2L), 5spd, 146,000 Miles all Original (even the clutch)
    Newbie Unot2fast4me is a glorious beacon of light
    Feb 2009
    Louisiana
    Yeah they will plug right up. I just did the same thing on my 06. You have to remove door panel from bottom only and the wires actually plug into the bottom of your window and door lock swithes from inside the door. It will start working as soon as you plug it in. The only mirrors you have to get programmed are the ones that are power folding with the curbview feature.
  5. #5
    Master Mechanic daddytech is a glorious beacon of light
    Mar 2008
    Portland TN
    not a whole lot of help on the newer ones but traditionally the wires are there, makes it easier when you select something at the dealership that isn't already on the vehicle. if you don't have to change out the wiring it may require you adding a fuse in the proper spot on the fuse panel either under the hood or on the one inside.
  6. #6
    Newbie luweee is a glorious beacon of light
    Aug 2009
    Omaha Nebraska
    Unot2fast4me
    hey I would like to do to a 05 silverado z71... had power mirrors no heat.... So all i do is buy mirrors with heat and it will work? how bout controls or are they automatic? Also how bout the ones with turn signals in them?? will that work too?
    THanks guy
  7. #7
    Dec 2008
    Washington State
    Quote Originally Posted by 05azsilver View Post
    It looks from the wiring diagrams from the link above that the heated and signal mirros should hook right up and work, but I am left with one question; how does the heater function get turned on? Does it come on when you enable the rear defogger, or do we also need to get a new door switch cluster?
    Volant CAI
    Optima red top
    Leer 100XL cap
    Line-x bed liner
    Cat back
    Alpine amp & sub
    Garmin Nuvi 255 GPS
    ScanGauge II
  8. #8
    Aug 2009
    Omaha Nebraska
    I agree jmutto.
    did you install them yet?
    kind of the last link to my question.. then i will be doing this my self.
    looks like you can put the ones on with turn signals too!
    let me know what you find out.
    thanks
  9. #9
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    I know that on my 99 they are automatic (mirror defrost) but on other vehicles (companies) they come on with the rear defroster and some even have a specific side mirror defrost button. My guess is GM still just has them automatic but that could change through the years and redesigns of vehicles
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  10. #10
    Newbie emdf7a is a glorious beacon of light
    Dec 2009
    Byron Illinois
    On my 08 Z71 the heated mirrors come on when I turn on the rear defroster. I actually had to ask the dealer about this as it wasnt in my manual. I would love to add the integrated mirrors to my truck. I wonder if I can add the fold away ones by replacing the switch too.
    Jason
Similar Threads
  1. Part swap/compatibility ?'s
    By LeDevil in forum Lifted & Offroad Suspension
    Last Post: 01-27-2010, 12:52 PM
  2. Rear end/differential Compatibility
    By tahoe101 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 10-06-2008, 05:42 PM
  3. A question about seat compatibility
    By Kraziken in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-09-2008, 02:44 PM
  4. Rear end/differential Compatibility..HELP!
    By tahoe101 in forum Powertrain
    Last Post: 06-25-2008, 04:54 PM
  5. Brake rotor compatibility?
    By Sabre7 in forum Lifted & Offroad Suspension
    Last Post: 01-28-2008, 10:16 AM
