GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 285 Tires
  1. #11
    The thing is you guys have totally different body styles. The newer trucks might not be able to run tires that large without trimming.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
  2. #12
    just put 85/70-17 on my 08 2500hd today with leveling kit . Rides better and 4 wheel fixed my speedometer. has always been off and is correct now. No rubbing and they reprogrammed the TPMS system. This is on stock 17x7.5 rims
  3. #13
    i think you will def. need a leveling kit for the new body's... 285 are too big to run without anything... rc has inexpensive kits check em out... the tires looked huge on mine without a lift, like WAY TOO BIG... i couldnt even turn half way
    2008 NBS Silverado Z85
    4.8 V8
    -8000k HIDS
    -AVS Bugflector II
    -20% tint all around
    -17x9 Moto Metal 951
    -Rough Country 2'' Leveling Kit
    -Putco Window Visors
    -Blacked out headlights (courtesy of JAKD-UP)
    -285/70/17 BF Goodrich All Terrains (minimal rubbing still) :grrrrrr:
    -Blacked out grille and both bumpers
    -Smoked taillights
    -Blue interior dome lights
    "A work in progress is something every man should have"
  4. #14
    Jr. Apprentice bandy's Avatar
    Feb 2009
    Canada Quebec City
    Quote Originally Posted by Duncan_Z71 View Post
    i have them on my 01 silverado. Without a lift. But I dont think the 08 would have any problem?
    I'm silverado 1500HD 2001
    285/75 16 bfgoodrich all terrain on it no problemo fit perfect no mod
    very good look
  5. #15
    I think the important think to consider here is that 285 is the tread width,the aspect ratio and rim diameter is what determines the height of the tire, for example
    285/55/20=32.34" tall
    285/75/16=32.83"tall
    285/75/17=33.83"tall
    also you need to consider the backspacing of your rims. GM generally use a 31mm or 20mm offset on their factory wheels so if you go to a rim with less offset it is going to push the tires to the out side of the truck causing them to rub. I have a set of 20" GM rims with a 31mm offset and I'm planning to put 305/50/20 size tires on (32.05"tall) I'm fairly sure they're gonna fit o.k. but I'm replacing the torsion keys any way to give the truck a better stance
    Good Luck and I hope I helped!!
    Adam
  6. #16
    Newbie wlstiger01's Avatar
    Apr 2008
    Cerritos,ca
    i go p285/65/18 on my 2001 silverado and i have no problems my truck is stock your truck sits higher than mine you should be good
  7. #17
    Quote Originally Posted by wlstiger01 View Post
    285/65/18=32.58"tall
  8. #18
    I think it is going to be iffie..... The key is to have stock wheels. I think as soon as you go aftermarket and wider, they are going to rub. See if you can have them test fitted.
  9. #19
    Sr. Apprentice fx2offroad's Avatar
    Oct 2008
    Yukon, Oklahoma
    They will rub in the front without a leveling kit!
    Greystone Matalic, LS
    Audio Mods: Kicker S8L7, Kenwood Amp, Pionner rear speakers
    Electronics: Viper 5701 Security/Remote Start
    Interior: 10% tent,
    Exterior: Bug Shield, OEM bed rails protectors, toolbox, tonneau cover, debadged.
    Engine Mods: Airaid Intake
    Suspension Mods: Superlift 2.5 in. lift struts, Procomp 2" add-a-leaf in the rear.
  10. #20
    I agree no doubt they will rub on the new body. Mine did. You will have to get the 2" leveling lift..
Similar Threads
  1. Bridgestone Tires - Replacement Tires
    By jhonydeep in forum Wheels & Tires
    Last: 05-03-2010, 08:03 PM
  2. Need some help with tires please!
    By WSD1975 in forum Wheels & Tires
    Last: 01-18-2010, 07:29 PM
  3. Tires tires tires Arg! 10ply vs others Road hazard
    By Dr_Zero in forum Wheels & Tires
    Last: 02-20-2009, 01:09 PM
  4. Blizzak tires, snow tires need advice.
    By EdPDX in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-12-2007, 06:58 AM
  5. What tires to get?
    By wakejim in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-04-2007, 02:01 PM
