Thread: 4wd clunk
    Legend bry2500's Avatar
    Oct 2008
    Gloucester, MA
    Default 4wd clunk
    Each time I drive in 4wd i hear a loud clunk, mostly during slow tight turning but also sometimes just when starting to move straight ahead.almost sounds like a u joint but super loud. I have checked every thin out and all seams tight and not worn. I know whata cv joint sounds like when it's going and this definitely is not a cv joint. I has almost a ping noise to it like if you were to push a dent out of sheet metal. Any thoughts?
    also it is mostly when driving in reverse and turning.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
    4wd's don't like to turn tight when in 4wd, especially on dry pavement. A clunk in those situations is normal, but try to avoid them because it will damage the transfer case. The noise you hear when just starting out could be a little play in the transfer case. Someone else can probably help you some more.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    Sounds like the 4wd binding up and releasing. Normal in 4H/4L on a good traction surface, though it does indicate that something will likely break if you continue the practice. 4H/4L should only be used when traction is poor enough to allow the wheels to slip.
    I had a truck do something similar when I had mis matched tires (same size but different manufacturer). The size difference between manufacturers was enough to cause the drivetrain to bind up and release with a clunk.
    Oct 2008
    Gloucester, MA
    I do have different manufacturer tires, they are the same size but the rear look a smidge smaller. I thought it was an optical illusion because of the front end rake on the avalanche. Looks like I have to find 4 new tires. Thanks for the quick replies guys.
    BRYAN
    8.1L Vortec
    43,000 miles
  1. Clunk!
    By bello926 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-19-2010, 01:37 PM
  2. Clunk!
    By markman34 in forum GM Powertrain
    Last Post: 05-26-2010, 05:04 PM
  3. Clunk clunk?
    By Iowa.Bowhunter in forum Lifted & Offroad Suspension
    Last Post: 06-16-2009, 10:59 PM
  4. Clunk at take off.
    By RVJ in forum GM Powertrain
    Last Post: 11-17-2008, 08:45 PM
  5. Clunk!
    By russski1 in forum General Chevy & GM Tech Questions
    Last Post: 07-02-2008, 07:32 PM
