Anyone have any issues with the bass, mid, and treble settings on their factory radio resetting back to neutral every so often? It's happened a few times in the last 2 months, but I'll turn the truck on and the way I had it set will go back to factory stock. Kinda annoying.
Ruby Red Metallic 2008 Silverado Z71 Ext Cab -- Rancho 4" Lift, 20x10 Chrome XD Rockstars, 305/55/20 BFG Mud Terrains
Haven't had it happen in the truck yet but my 07 Cobalt ss/sc would do it every now and then
2008 Silverado 1500 Ext Cab 4wd LT1 Package with 20" wheel upgrade,K&N CAI, Magnaflow Catback Dual Side Exit, Tuff Country 2" Leveling Kit, Blackbear Tune, 6k HIDS Low and High Beams, 3K HID fog lights, LED tailight bar
I have had the same prob with the stock am/fm in my '05 Silverado W/T. Every one in a while I would turn the radio on and all settings would be at the most neutral degree. Could not determine any pattern as why it would do this. Solved my problem by replacing with a Kenwood CD player.
Keep Drivin' -Pete.
Sounds like the 24 hour power wire is not providing full 24 hour power. Do you loose all of the prests as well?
Trevor - Huntington Beach, CA
2007 GMC 2500 4X4
My boyfriend's colorado does the same thing, every time you take the key out of the ignition. When you start the truck up again, the bass will be all the way turned up along with the other stuff. We still haven't figured it out yet, his keeps all the presets and other options too????
Bookmarks
