Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Jr. Engineer mjalstad is a glorious beacon of light
    Jan 2009
    Rochester, MN
    Default Headers, long tube or shorties?
    So I've been thinking about getting some headers. I see on Summit's website they have Pacesetters for pretty cheap. The shorties are $240 and the long tubes are $290. What are the pros and cons of each of these? searching around, it sounds like shorties bolt directly up to the stock flange and so they install really easy but the long tubes have a lot better power. So it's sounding like the long tubes are the best ones, so I basically have two questions: 1 - how much more will long tubes perform than short tubes and 2 - how much more difficult are the long tubes to install? I don't really understand how the long tubes connect to the rest of the system, in the description it says "collector attachment: slip fit" do they need to be welded or what?
    Short tubes
    Long tubes
    99 Silverado Z71 4.8
    2" Suspension lift (Add-a-leafs and leveling keys)
    Long tube headers with 3" offroad Y-Pipe
    Volant Cold Air Intake with Ram Air Intake Tube
    Jet Mass Air Flow Sensor
    Diablosport Predator Tuner
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
    35" Yokohama M/T's
    K&N Intake
    Airraid Throttle Body Spacer
    Hypertech Programmer
    Dual Flowmasters
    Jr. Mechanic 1slols1 is a glorious beacon of light
    Jun 2007
    shorties are direct replacements for your stock manifolds.
    long tubes will require some modication or out right new pipes from the headers to the muffler.
    it shouldnt be too expensive to have an exhaust shop bend you up some pipes if you get the long tubes but i would call and ask
    2004 Silverado 1500 2wd Ext. Cab
    Sr. Apprentice FocuzTech is just really nice
    Jan 2007
    Actually for a street driven truck a mid length 4-2-1 or Tri-Y would be much better.
    01 2500 Burb 8.1
    71 Cheyenne 502 675hp
    Certified Gatorhyde Dealer/installer
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    This is from this month's issue of Truckin' magazine, I tried to download it but it kept messing up!
    SHORTY HEADERS VS. LONG-TUBE HEADERS
    PROS:
    Easy Installation VS. Greater low-end torque
    Most are CARB-approved VS. Often are not CARB-legal
    Bolt up to existing stock exhaust pipes VS. Deep throaty sound
    Provide good mid and upper rpm power VS. Broad low-rpm torque curve
    CONS:
    Lighter weight VS. Heavier than shorties
    Not as much power made VS. Control torque/power curve
    Some times less quality means flange leaks VS. More expensive
    Compact design can be hard to install VS. Often hang below framerails
    "We looked at both types of header's and for all-out performance with NO carb issues, it's hard to beat long-tube headers, but if you're on a budget and you want smog-legal performance, shorty headers are the way to go!......................Hope this helps, AMY
  5. #5
    Jan 2009
    Rochester, MN
    I guess my other question would be about the coating. I do live in minnesota so I deal with the salt, so should I splurge and get the expensive coated ones? My truck is a 99 with 120K on it, so it's not like I'm going to have it for 10 years or anything. I found the headers with an offroad y-pipe that will connect the headers to my stock mounting flange behind the cats for $400 without the coating so I'd like to save some money by going with that.
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    35" Yokohama M/T's
    K&N Intake
    Dual Flowmasters
  6. #6
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    My dad had a set of ceramic coated long-tube headers on his 57' chevy and loved them!
    On my old 2500HD Silverado, I had a set of Stainless steel HOOKER headers, that were shorties and I really liked them as far as sound and fitment went.
    If I had to buy another set of headers, I would buy the shortie ceramic version they seem to hold up better over the long haul.
    With your truck having that many miles on it, I don't think I would shell out the extra money for the coating either. $400 sounds pretty reasonable in my opinion, then again I tend to splurge on stuff like that
  7. #7
    Jr. Mechanic 05azsilver is a glorious beacon of light
    Mar 2007
    Chandler, AZ
    Most headers are coated anymore. As for your other question I prefer shorties due to the ease of installation.
    Chris
    2005 Silverado - 4.3L, 5spd Manual, K&N Drop in Filter, Modded Air box
    Kenwood KDC-MP732 Head Unit, Pioneer 760W Amp, 2x 10" MTX Thunder 6000 subs, Uniden PC68XL CB/PA
    2004 Cavalier - 2.2L Auto
    Bone Stock
    1977 Toyota Celica GT - 20R (2.2L), 5spd, 146,000 Miles all Original (even the clutch)
  8. #8
    Jan 2007
    Definitely get them ceramic coated it helps with underhood engine temps and keeps the headers looking nice.
    01 2500 Burb 8.1
  9. #9
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    I've always been a fan of block huggers or shorties. Unless you are doing a full exhaust replacement, go the easy route. If your motor doesn't need equal length tubes for performance reasons, shorties are perfect.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
  10. #10
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    Sorry to hijack this thread, but I gotta ask. How much (if any) performance gain (or mpg gain) is there with shorties over stockers? Is it worth the extra money?
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
Similar Threads
  1. Shorty Headers vs Long Tube Headers
    By rackchaser71 in forum Performance & Fuel
    Last Post: 06-18-2011, 01:13 AM
  2. Long Tube Headers
    By Metaluzc in forum Performance & Fuel
    Last Post: 06-18-2010, 01:33 PM
  3. Which long tube headers?
    By chevytruckman in forum Performance & Fuel
    Last Post: 11-23-2009, 11:38 AM
  4. long tube headers for 09 1500
    By ahmitchell1 in forum Performance & Fuel
    Last Post: 09-04-2009, 05:18 AM
  5. Long Tube Headers
    By willbradfan in forum Performance & Fuel
    Last Post: 07-17-2009, 03:52 PM
