GM Truck Club
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: dead battery?
  1. #11
    Master Mechanic Dr_Zero's Avatar
    Mar 2006
    Sunny Florida
    Quote Originally Posted by vegaschevy View Post
    Update...after checker had it for overnight they called and said the battery was no good. Naturally the exact battery was not availble, went to a red top optima sealed unit and to get the terminals to configure correctly I had to upgrade $ 16.00. Seems to be doing the trick. Also took the time to read the brochure that came with it....yellow top for RV's and trolling motor....blue kinda an inbetween start and slow draw for as formentioned...red top for starting vehichles. Figure in another two years will be at it again, the heat is brutal on batteries out here in the desert. Can probably delete this thread now since problem solved...once again thanks for everyones help and input.
    Good to hear you are back up and running!
  2. #12
    Jr. Mechanic TMRuiz's Avatar
    Dec 2008
    Gonzales, Louisiana
    If it's the same battery I'm thinking of (Optmia gell cell) it happens alot with this battery for some strange reason. The battery terminals come loose over time acting like a dead battery. the only fix I ever found for this was to keep an eye on the connections. Good luck and I hope this helped.
    [/SIGPIC]07 Silverado LS factory 20's, spray in bedliner, in-bed cargo managment system, matching tint on front windows, K&N CAI, and Hypertech Max Engery Tuner and yet even more mods to come.
  3. #13
    Jr. Mechanic
    Dec 2008
    Gettysburg, Pa.
    Default dead battery
    http://www.batteriesareus.com/index....id=2&chapter=0
    Just thought I would post this link it is informative and it's important to understand that AGM batteries are great in many ways but they are a different animal so to speak when it comes to proper charging, same goes for the Gel Cell types also as they are even more unforgiving when it comes to heat and gassing.
  4. #14
    Sr. Apprentice wpnsgy's Avatar
    Feb 2009
    New Hampshire
    Could be a Short or Just a bad battery Have it tested or try another that you know is good battery failure is much more common than a short Good luck
Similar Threads
  1. Getting tired of dead battery. Help?
    By 95Chevyk1500 in forum GM Electrical Tech
    Last Post: 12-18-2009, 08:29 PM
  2. dead battery !
    By loic in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 08-31-2009, 07:01 PM
  3. Dead Battery
    By starultra in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 02-22-2009, 06:23 PM
  4. Can't recharge my dead battery
    By areotreker in forum Audio, Video & Gadget Tech
    Last Post: 11-03-2008, 06:36 PM
