GM Truck Club
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 30
Thread: Belt Squeal
  1. #11
    Gotta agree, look in the direction of the belt tensioner. one other thought, the suburban i used to own had a problem with belt squeal, turned out it was the belt! went through three new ones before i got one to shut up!!!!!
    Adam
  2. #12
    Sr. Apprentice
    Dec 2008
    Findlay,Ohio
    I would have to agree, belt tensioner , or maybe the clutch fan
  3. #13
    I have fought this same problem time and time again. Once you determine that is is not a pulley by removing the belt and spinning all of the pulley patiently and checking for noise or roughness, and checking the tensioner after removng the belt by moving that arm and making sure it hits the stop very positively (the spring should be strong), I recommend using a GATOR belt that can be found at NAPA. It is a serrated belt on the grooved side. Same Price. They seem to really reduce the noise. The only other thing I can suggest is make sure nothing is stuck in the pulley grooves (any of them) and I mean anything. Sometimes the slightest piece of material in the pulleys can cause noise. As a general rule, Belt Dressing is bad speaking from experience. It seems to fix nothing, maybe prolong an inevitable repair, sometimes. Good Luck...
  4. #14
    i had the same issue with my truck, i ended up getting a new belt and a new idler pulley, now i have no more squeaking =]
    2002 Chevy Silverado 1500 4.3 V6
  5. #15
    quick fix for belt squeal.
    When running take a large wire brush and run press firmly on the belt top and bottom for a few seconds.
    I use this method often after doing work to a vehicle and coolant or oil gets on the belt
    WARNING THE FAN CAN TURN ON AT ANY POINT.
    HOLD THE BRUSH TIGHT ONLY PRESS AS HARD AS NEEDED TO AVOID CATCHING THE BRUSH IN A PULLY
    DO AT YOUR OWN RISK IF NOT COMFORTABLE THEN DON'T DO IT
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
  6. #16
    Jr. Mechanic catbert's Avatar
    Sep 2008
    Tobacco Road, NC
    I just found from my dealer that there is a tech bulletin about squeeks under the hood. GM is telling techs to look at the alternater bearings.
    Don't think Meat - Throw the ball...Crash Davis
  7. #17
    Sep 2008
    Tobacco Road, NC
    Update...the latest cold start squeak WAS the alternator. Replaced under warranty, along with the belt.
  8. #18
    I chased this same problem a couple of months ago,it turned out to be the air cond. belt instead of the supentine belt.It was a bear to figure out because I didn't know there was a seperate belt for the air. It's all the way down on the bottom left on my 03 sierra.
    Good luck
    Jay
  9. #19
    My 98 Sierra has the same problem, but it only squeals when it rains or it's wet outside... After driving it for a little while the squealing goes away.... I don't really know why this is happening, lol...
    1998 GMC Sierra 1500 5.0L 4x4
    2002 Dodge Durango SLT Plus 4.7L 4x4
    2007 Nissan Altima 2.5 S
  10. #20
    Sr. Apprentice etpn13's Avatar
    Feb 2009
    new market, tn
    i started out w/ a little chirp in my belt. then it became a vibration noise that happened every once in a while after i put my intake on and just thought it was the intake vibrating the fan shroud. it got worse today and come to find out my alternator bearings are shot found metal shrapenal under the hood. gonna replace the alternator tommorrow.
    01 silverado z71 5.3L
    mods: kenwood mp238 hu w/ sirius satellite radio
    kenwood 3 way 6 3/4 front door speakers. kenwood 4x6 rear.
    blaupunkt 200a powered sub.
    flowmaster 40 series dual exhaust.
    k&n 57 series cai
    vent shields
    bug deflector
    garmin 755t gps
    110,000 miles
    future mods: throttle body spacer, new plugs and wires, and programmer. a/t or m/t tires.
Similar Threads
  1. belt squeal on 305 vortec because of alternator pulley?
    By treykelly84 in forum General Chevy & GM Tech Questions
    Last Post: 12-17-2011, 09:59 AM
  2. Belt Chirp Squeak Not Squeal
    By Alaskan in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-19-2010, 03:11 PM
  3. Squeal
    By Lee Indy in forum Lifted & Offroad Suspension
    Last Post: 04-23-2010, 03:30 PM
  4. 6.0 v8 Squeal help!!!
    By H2inMd in forum GM Powertrain
    Last Post: 05-13-2009, 10:12 AM
  5. Squeal
    By chelsea in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 09-18-2006, 12:53 PM
