I was thinking about getting a KN FIPK put on my truck. Someone had told me that it is worthless to do without also getting a MAFsensor.
Any truth to this? any reason i should spend 300 more bucks for the new sensor?
any gains or knoticable difference?
thoughts?
Thanks.
2004 Silverado Crew Cab-z71-4x4-5.3-100k+ miles-KN FIPK Stage 2 CAI-Flowmaster 40 muffler w/ dual tip-Apline deck/alpine amp, Pioneer components front/Pioneer Back/2x10" MTX Subs under rear seat-Cooper ST tires
There is no truth to that. Many many people here can tell you that adding an intake is a great upgrade. I installed an aftermarket MAF and found it did give me better throttle response and horsepower, but so did the intake. Also if you get a new MAF, you better have a way to custom tune it such as a predator or a nelson/blackbear tune because the Maf will be letting in more air than it thinks and you will run borderline lean which can cause plenty of problems.
99 Silverado Z71 4.8
2" Suspension lift (Add-a-leafs and leveling keys)
Long tube headers with 3" offroad Y-Pipe
Volant Cold Air Intake with Ram Air Intake Tube
Jet Mass Air Flow Sensor
Diablosport Predator Tuner
Previous Truck:
97 Suburban K1500
3" Body lift
2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
35" Yokohama M/T's
K&N Intake
Airraid Throttle Body Spacer
Hypertech Programmer
Dual Flowmasters
ya--im going to forgo the MAF for now, as i've had other people tell me its not sensible for 300 bucks unless i was to get other upgrades and a upgraded throttle body.
i ended up just getting a Hypertech Max, and fipk CAI..well see what that does for me.
Bookmarks
