Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: smelly a/c
    Newbie emjcfj is a glorious beacon of light
    Jan 2009
    Default smelly a/c
    i have an 06 silverado and when i turn on the a/c i get a rotten egg smell. has not happened during the winter.anyone have this issue?
    Jr. Mechanic GOTSAND4ME2 is a glorious beacon of light
    Apr 2009
    Ukiah, California
    HI there
    Have you tried changing the cabin air filter?? A buddy of mine changed his and he got rid of a similar smell
    Brian
    Nor-Cal
    2000 Chevy Silverado 1500
    6" RCD Lift
    315/75/R16 BFG All Terrains
    Alpine 7" DVD Reciever
    Jbl Componet Door Speakers Front and Rear
    4 10" Jbl Subs
    Led (Blue) Cluster Gauge Blulb Swap
    Dell Studio Hybrid Digital Media Server
    Cobra CB
    Twin Bearcat Scanners
    Jr. Apprentice vegaschevy is a glorious beacon of light
    Jan 2009
    Fabulous Las Vegas
    Quote Originally Posted by emjcfj View Post
    I agree with the gotsand4me guy..try the cabin air filters first.. then you might have got some mold issues going on or possibly a piece of debris in the evaporator core housing and or its drain tube.
    Jr. Engineer drumrob is a glorious beacon of light
    Sep 2007
    San Diego
    you can change the filter and if that doesn't work change your deodorant!!!
    07 SILVERADO Ls
    K&N Intake
    Hypertech Max Energy
    6" PRO COMP LIFT
    PRO COMP 17" RIMS 33" goodyear shoes
    Pioneer Avic D3 nav/DVD
    Chrome running boards
    Chrome door handles
    Dual tv/dvd in headrest
    Flowmaster
    HID's (8000k)
    Rear view camera
  5. #5
    Jr. Apprentice 98GMCSierra1500 is a glorious beacon of light
    Apr 2009
    Columbia, SC
    I have the same problem with my 98 Sierra... Does it have a cabin air filter too?
  6. #6
    Master Mechanic Dr_Zero is a name known to all
    Mar 2006
    Sunny Florida
    You ever listen to Car Talk? They had a guy call in with a similar situation and they said to read the lables close of the produts they sell for smelly ac's one was just alcohol.
    They suggested looking at the cowl vent for a build up of trash and moldy leaves and clean them out and wash out the gunk and it should help.
    If you got the cabin filter would change that out also after cleaning things out.
  7. #7
    Sr. Mechanic 1_low_rider is a glorious beacon of light
    Apr 2009
    Mississippi
    Yea I would say change the cabin air filter then possibly look at the heater core, they are bad to go out
    Scott-Mississippi
    2002 Silverado
    *Stock 5.3 engine
    *DJM 5/7 lowering kit
    *20in. Boss 330 wheels on 255/35's
    *3in. BBK headers into dual 1chamber Flows
    *Airaid Coldair Intake and Hypertech programmer
    *Shaved doors, tailgate, taillights, 3rd brake, and stake pockets
    *Smooth roll pan with tag and LED brake lights frenched into tailgate
    4 SALE - $6000 Firm
  8. #8
    Legend MWright936 is a glorious beacon of light
    Mar 2008
    Hallsville, TX
    Could someone take a picture showing the location of the cabin filter? I have had this problem as well, and people suggested the cabin filter, but I can't find it. Thanks!
    Matt
    Hallsville, TX
    2005 Silverado 1500 LS Crew Cab 5.3L 2WD
    K&N FIPK II
    Magnaflow Exhaust
    Hypertech Max Energy Programmer
    Suspension Leveling Kit
    Putco Element Window Visors
    Carriage Works Billet Grille
    TruXedo TruXport Tonneau Cover
  9. #9
    Jr. Engineer mjalstad is a glorious beacon of light
    Jan 2009
    Rochester, MN
    The air filter doesn't make sense because if that was the problem, you would have stinky heat too so I wouldn't waste my time on that. I know there is a TSB for my GF's 06 Grand Prix about stinky AC that applied to a lot of models and I think the cause was water in the casing or something. I think they recommend drilling a hole in the bottom to drain it out and then putting some oil or something in there. Sorry I'm not too much help with that but hopefully I'm helping to steer you in the right direction.
    99 Silverado Z71 4.8
    2" Suspension lift (Add-a-leafs and leveling keys)
    Long tube headers with 3" offroad Y-Pipe
    Volant Cold Air Intake with Ram Air Intake Tube
    Jet Mass Air Flow Sensor
    Diablosport Predator Tuner
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
    35" Yokohama M/T's
    K&N Intake
    Airraid Throttle Body Spacer
    Hypertech Programmer
    Dual Flowmasters
  10. #10
    Mar 2006
    Sunny Florida
    Quote Originally Posted by Dr_Zero View Post
    Subject: Passenger Compartment Air Filter - keywords dirt dust HVAC
    interior #PIT3330A - (02/16/2006)
    Models: 2003-2006 Cadillac Escalade Models
    2003-2006 Chevrolet Avalanche, Silverado, Suburban, Tahoe
    2003-2006 GMC Sierra, Yukon Models
    2003-2006 Hummer H2
    The following diagnosis might be helpful if the vehicle exhibits the
    symptom(s) described in this PI.
    Condition/Concern:
    A customer may inquire about the availability of the passenger
    compartment air filter.
    Recommendation/Instructions:
    Starting in the 2003 model year, the passenger compartment air filter is
    no longer available as a factory option. With the redesigned HVAC case,
    there is no longer a cavity for the filter. The GM parts catalog
    indicates there is a replacement filter available however there is no
    provision for it.
    Please follow this diagnostic or repair process thoroughly and complete
    each step. If the condition exhibited is resolved without completing
    every step, the remaining steps do not need to be performed.
    GM bulletins are intended for use by professional technicians, NOT a
    that could assist in the proper service of a vehicle. Properly trained
    technicians have the equipment, tools, safety instructions, and know-how
    to do a job properly and safely. If a condition is described, DO NOT
    assume that the bulletin applies to your vehicle, or that your vehicle
    will have that condition. See your GM dealer for information on whether
    your vehicle may benefit from the information.
    WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
    (c) Copyright General Motors Corporation. All Rights Reserved.
    Thanks,
    Mike Griffin
    Fixed Operations Director
    SouthPointe Chevrolet
