Results 1 to 8 of 8
Thread: wucky
    Newbie wucky is a glorious beacon of light
    May 2008
    savannah, ga
    Talking wucky
    old guy and a '99 silverado needs a new 5.3L and transmission ( '71 MGB-GT needs the old). besides the computers, engine and transmission what other parts do i need?
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Welcome to the site!
    Darcy
    Washington State
    Jr. Engineer werty is a glorious beacon of light
    Jun 2008
    romperland
    IM confused?are you putting the 5.3 into a mg??
    Legend retired2001 is a glorious beacon of light
    Nov 2006
    Canyon Lake, Texas
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
  5. #5
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
  6. #6
    Legend MWright936 is a glorious beacon of light
    Mar 2008
    Hallsville, TX
    Welcome! Sounds like you've got quite a project (or projects) ahead of you!
    Matt
    Hallsville, TX
    2005 Silverado 1500 LS Crew Cab 5.3L 2WD
    K&N FIPK II
    Magnaflow Exhaust
    Hypertech Max Energy Programmer
    Suspension Leveling Kit
    Putco Element Window Visors
    Carriage Works Billet Grille
    TruXedo TruXport Tonneau Cover
  7. #7
    May 2008
    savannah, ga
    Default wucky
    i hope to upgrade my '99 silverado with a late model 5.3L and 4L60 transmission which calls for changes to the newer computers as well. i hope to install the present 5.3L and 4L60 units into a '71 MGB GT i am doing suspension and body work on at this time. loads of work so i have to live a long time! thanks for the welcomes.
  8. #8
    Legend bry2500 is a glorious beacon of light
    Oct 2008
    Gloucester, MA
    Welcome to the site!!!
    Don't forget about cooling. You'll need a sufficient cooling setup for that Toy. I know if I had it it would be driven hard. MG's might not have enough airflow to keep the coolant temp in a safe range. Definitely look into some hi flow puller fans (ie. Flex-a-lites).
    Also if you are using the stock fuel pump that is in the MG make sure it can can supply enough pressure.
    Oh and leave enough in your budget for a custom exhaust.
    There has got to be other thing's but those are the quick items that I thought of.
    HAPPY MODDING!!!!!!
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
Similar Threads
  1. wucky
    By wucky in forum Member Introductions
    Last Post: 06-23-2008, 12:21 PM
