Results 1 to 7 of 7
    Legend phoebeisis has a brilliant future
    Jun 2006
    River Ridge Louisiana-4 miles W of New Orleans-didn't flood-water stopped 800 yards away.
    Default Replacing rear main seal 98 Suburban 2wd
    I changed the oil yesterday-1st time in about 8 months that I was under it(but it might have been leaking,I wouldn't always notice a leak)
    I notice an oil drop on the filter,and oil kinda "around" that general area.
    I don't think that the filter o-ring was leaking,and it was oil, not trans fluid.
    Is this probably from the rear main seal-208,300 miles?
    How difficult a driveway repair- jack stands etc- is this? How many hours-10-20?? for an amateur without air tools(but I might buy a compressor finally.
    Thanks,
    Charlie
    PS I would be tempted to change out the motor( $2300 delivered for a new goodwrench GM motor), but this one gets such good mpg, and I'm broke(in debt, medical bills etc despite insurance), so I'll probably stay with this motor.I could credit card it-a new motor- probably.
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    A good possibility.
    Why dont you clean the area up real good with some degreaser and keep an eye on it for a while.
    This is a tough one, with that kinda mileage I dont think you'd find many people recommending replacing a rear main seal.
    The engine has to be lifted at least a few inches to get the oil pan out to get at the rear seal.
    Depending on the type seal your engine is using (1 piece or 2 piece) you may have to separate the engine and trans to get the new seal in.
    Have you thought of a low mileage used engine?
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
    Jun 2006
    Tim,
    Thanks for the response- not much forum response usually means it is an " oh, no" type question! Yeah, that would be a lot of work to fix a very old motor.
    I will get under it today and really clean the area.
    Just how will a leaking seal act? Will it just slowly increase the rate of leakage- OR will it suddenly become a gusher?
    If the likelyhood is that it will just continue to slowly leak-1 qt per 2000 miles or so-than I'll just keep and eye on it, and replace oil until I can afford to replace the motor. If they suddenly become gushers, then it is a different story.
    I'll clean it up once it gets a little warmer-coldish and wet today.
    Thanks,
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    You will have to pull the transmission to get at the rear seal (1 piece). If it were me and only dripping a small amount (not covering the underside of the truck in oil) I would let it alone and just keep an eye on the oil level.
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
  5. #5
    Jun 2006
    Gary,
    Thanks for the response. It used about 1 quart per 2500 miles on two 3000 mile roundtrips-all highway- last summer-maybe 2.5 quarts over 6000 miles of 68 mph travel.
    I just assumed it was using-burning oil getting past the rings or the valve guide seals- for all I know it has been slowly leaking at that main rear seal for the entire 13000 miles I owned it.
    The motor gets such great mpg I hate to just junk it.
    Just eyeballing the dipstick and the drip-never noticed any under it, but I wouldn't notice the few drips it would make while off.
    Yeah, just watch and wait might be the ticket for now.
    Any idea if they -rear seal- just slowly increse in leak rate, or do they become gushers? Or is the answer-"sometimes they stay slow, sometimes they gush-no way to predict either way"
    Thanks,
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
  6. #6
    Moderator
    Mar 2006
    The Colony, Tx
    I've personally never seen one gush, but I'm sure it has happened to someone. Just keep an eye on it and you should be fine. I wouldn't junk a motor for a little oil usage. The 454 in my 78 has used a quart of oil every 3,000 miles since the day my Grandfather drove it off the lot new, but it never leaked.
    Gary
    99 K 1500 Suburban
    1977 Formula
    1976 Trans Am
  7. #7
    Jun 2006
    GaryL,
    I like that plan. I mainly just drive it around the city,so if It breaks down,so what.Once or twice a year we drive to Flagstaff-3000 miles roundtrip, but that is at least 4 months off. So if it justs steady leaks 1 qt per 1000-1500 miles, so what.
    The motor is really sweet otherwise gets great mpg-15 city 21 hy-so I would hate to dump it.Besides, we have big $$ problems right now. I would rather limp along for another 1.5 years when my $$ woes will be less.I would like to get a 2004 with 60,000 miles then.They are maybe $13000 now, but if gas goes up again, they will drop in price just like before.I won't care-I like the Suburban enough to keep it at $8 gal.
    Thanks,
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
Similar Threads
  1. Rear Main Seal Leak Please help!
    By silveradokid in forum General Chevy Tech Q&A
    Last Post: 04-12-2010, 12:49 PM
  2. Rear Main Seal
    By Silverado Junkie in forum Powertrain
    Last Post: 03-27-2010, 06:48 PM
  3. rear main seal
    By tcook18 in forum Powertrain
    Last Post: 02-03-2010, 11:55 AM
  4. Rear Main Seal repair
    By eddave in forum Powertrain
    Last Post: 05-09-2009, 11:13 AM
  5. Replacing front output seal 99 suburban
    By coloradosuburban in forum Powertrain
    Last Post: 11-17-2007, 12:04 AM
