Results 1 to 9 of 9
    Ft. Wayne, IN
    Default valve adjustment?
    allright, i have a question about the valve adjustment on my truck...
    it is a 92 reg cab long bed with a 355 (.030 over 350)
    tore it down to replace the headgaskets and pulled the heads, and intake manifold, while replacing the gaskets i noticed the clip that holds the hydraulic lifter together had come apart.
    so i got a new set of lifters and installed them, adjusted the valves per service manual. however i did not prime the engine with oil beforehand. got it back together and fired it up and seems to run like crap...
    my question is, since i did not prime the engine, do i need to readjust the valves and see how that does? i'm sure the timing is set, i'm kinda lost on this and need the truck back asap... thanks for reading and replies.
    92 Silverado 2500 "tow bi***"
    355 v-8 2wd dual exhaust
    90k miles
    00 Jeep Wrangler "toy"
    2inch spring spacers, 1inch body lift on 35's with cut fenders
    4.0 inline six, 5 speed
    I've never been very successful adjusting the valves per the factory service manual. I've always had much better results adjusting it while the engine is running. It's somewhat a pain because you have to unplug a bunch of wires and hoses to get the valve covers off, then plug in enough wires and hoses to get the engine to start and run, yet still provide clearance to reach the adjusting nuts.
    Plus, you should install little clips on the oil squirt holes to keep oil from spritzing out.
    The trick is to turn the adjusting nut s-l-o-w-l-y. Turn the nut out s-l-o-w-l-y until you hear a definite clatter from that valve (it's unmistakable). Then s-l-o-w-l-y turn the nut back in 3/4 (or is it 1?) turn. If you turn the nut in too fast then the lifter won't bleed down and it will clatter at any position.
    YouTube has a number of home videos of the technique. It works quite well and is accurate.
    That being said, I don't know if it will fix your truck but at least you've eliminated a variable.
    Kirk
    Norwalk, CT
    +1 on adjusting the valves with the motor running vs. using the manual. I've never actually even done it per the instructions in the manual.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Kirk has the right idea, but it's backwards. You need to loosen the nut until it starts to clatter then slowly tighten it back until the clatter stops and then tighten and additional 3/4 turn.
    And as he said, find some rocker clips at your local parts store to put over the top of the rockers to keep the oil from squirting all over the place while you are doing it.
    Good luck.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    Ft. Wayne, IN
    ok, i readjusted the valves, did not run while adjusting due to lack of oil control tools (can't make a mess of oil everywhere as i am not at my garage). got the valves adjusted and put back together and idles great. my only new concern is i think i have a timing issue, it idles great but while driving underload it doesn't have alot of power. also if i try to kick it down a gear and speed up it just backfires and boggs down... sound like a timing issue?
    That sounds like a timing issue to me. You say you have a 355 in it, is it carbed or still TBI?
    Quote Originally Posted by GaryL View Post
    Doh! I just re-edited my post. That'll learn me from posting late at night....
    Ft. Wayne, IN
    it is tbi. its a .030 over rebuilt 350.
    Try resetting the timing. There is a timing advance wire you have to unplug (brown wire near the distributor on the firewall with a plug connector.) Start it up with the wire unplugged and set timing to 0 degrees BTDC. Turn off engine. Plug wire back in and computer takes over. See if this gets you back in shape.
  1. Valve adjustment on 1997 350 vortec suburban
    By ahlberg in forum GM Powertrain
    Last: 02-28-2010, 07:57 PM
  2. window adjustment
    By gargoyle725 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 07-29-2009, 06:26 AM
  3. tie rod adjustment
    By skipbeau3790 in forum Member Introductions
    Last: 11-02-2008, 10:36 AM
  4. Fender Adjustment
    By Trex in forum Chevy Colorado Forum (GMC Canyon)
    Last: 05-12-2008, 03:48 PM
  5. Brake proportioning valve adjustment?
    By Sabre7 in forum Lifted & Offroad Suspension
    Last: 03-03-2008, 08:54 AM
