GM Truck Club
Page 2 of 9 FirstFirst 1234 ... Last Post byLast Post by
Results 11 to 20 of 88
  1. #11
    I called my dealer because my check engine light came on, they want $100 just to pull the code....I went to Auto Zone, they pulled the code for free. I was told in was the EVAP Solenoid.....more of an expense than I can afford. Will this proceedure help my situation ???...from what I was told on another website, it is caused by dirt.
    *Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming - "WOW, What a ride!"
  2. #12
    Quote Originally Posted by jccams View Post
    My Chevy dealer supposidly hooked up the smoke machine and told me the problem was the vent valve.
    Jeff
    p0440 should be an evap leak where as a p0446 is a restriction... if they did a smoke test and told you your vent valve was leaking then cleaning it will not fix it... you would most likely have to replace it...
  3. #13
    Sr. Apprentice
    Feb 2009
    FT. Wayne, IN
    Quote Originally Posted by mrjcrod View Post
    X2 Agreed!
    2003 Silverado LS 1500 Xcab 5.3 vortec 3.73 rear.
    2000 Artic White Buick Regal GS, 3.4 pulley, 3"dp, 13.81 @ 101 (sold)
    2002 Z28 Camaro, 1sc, a4, slp lid, headers, cb exhaust, 3.73
  4. #14
    can someone take a picture of this valve considering the picture posted tells me nothing and i can not find this damn thing
  5. #15
    Look in between the cab and your box, it's on top of your gas tank, in between the cab and box, you can get down under your truck and look up, it's black and can fit in the palm of your hand.
    www.youtube.com/ippielb
    2002 Chevrolet Silverado 1500 z71 1985 Chevrolet Silverado k10 2006 Chevrolet Silverado 2500hd 6.6l LLY Duramax
    6.5" BDS Suspension Lift Edelbrock Carb & Polished Intake Manifold & Valve Covers NAPC Race Transmission & NAPC Built Transfer Case
    EFI Live Comp Cam and Valvetrain Snow Performance Methanol Injection
    35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's Headman Long Tube Headers and True Dual Exhaust FASS 150gph Titanium Series Pump
    AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer 2" Suspension Lift 33x12.50r15 Tires EFI Live & AFE Stage 2 Intake
    Pacesetter Long Tube Headers with Cats Gone True Dual Exhaust FlowPro 3.73 Gears Yukon Grizzly Locker with Mag-Hytec Cover & Traction Bars
    NGK Iridium Tips & MSD Ignition Plug Wires Baja Spare Tire Holder 33x13.5 Hankook rt03 18" XD Rims
    Innovate LC-1 Wideband o2 Sensor x2 HID's all around LED taillights and 3rd brake light
    BDS Dual Steering Stabilizers Pioneer Double-DIN Touchscreen Navigation with Two 10" Subs under rear seat
    Electric Fan Autometer Pressure, Boost, and Pyro Gauges
    4.56 Gears Airlift Air Bag Suspension
  6. #16
    so i finally had a chance to get down under the truck and take a look, after looking i found nothing on the front of the tank but i did find this on the back (rear) i took a picture now what in this pic am i cleaning?
    Click image for larger version.
    is this it, i found it on the pass side in the middle of the tank
  7. #17
    I believe it is the first picture.....at least that is what I went after today on mine (2006 E/C).....from looking at your picture...to the left, around the other side of the canister, there is a tab that you press down on and slide the canister to your left to get it off the bracket.....with the entire thing in your hand, disconnect the wiring from the valve and twist the valve clockwise to remove it from the canister....it is slotted where it slides into the canister, so you'll need to reverse this (counter clockwise) to reinstall it back on the canister.....on the other side of this line is another area you need to seperate....it has a small clip as part of the connection that you pop off to remove it....once it is disconnected from both ends, blow it out with a compressor....reconnect. I did mine earlier, still have the light on, but I only drove it a few miles today, maybe soon it will go into a test mode and see that it's fixed (I hope), otherwise, I have no idea how to clear the code.
  8. #18
    thx, was able to get under today and went exactly the way u said. i pulled thee whole thing apart and it was mighty dirty but definatly not clogged but lets hope it solves the problem
  9. #19
    i've been having the same issues and have found this posting very helpful. i have located the canister but am having trouble getting the tab pressed down. help please!!!
  10. #20
    got it off and cleaned out. the check engine light is still on. does anyone know if you have to get it reset??
Similar Threads
  1. P0446 EVAP Code (check engine light)
    By ippielb in forum GM Powertrain
    Last: 09-30-2011, 02:56 PM
  2. error code P0446
    By snarl2004 in forum General Chevy & GM Tech Questions
    Last: 05-03-2010, 08:05 PM
  3. alarm code p0446
    By grubbs11 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-29-2010, 12:55 PM
  4. Evap Emissions?
    By BigJosh in forum General Chevy & GM Tech Questions
    Last: 09-27-2009, 02:53 PM
  5. '06 Colorado with a P0446 CEL code
    By Boxman7481 in forum General Chevy & GM Tech Questions
    Last: 07-22-2009, 07:15 PM
