Results 1 to 9 of 9
    Sr. Engineer zach45 is a glorious beacon of light
    Apr 2008
    staten island new york
    Default how to tell a 5.3 from a 4.8
    my friend wants to buy a silverado... he got this one down the right price and all..
    the seller says its a 5.3 .. but the car fax comes back as a 4.8 how can we tell... were going to look at it tonight ...
    08 5.3 silverado...toyo m.t 33 12.50 18 rockstars...leveled with 2" blocks...cherrybomb catback...6k hids
    Legend
    silveradotrailblazer has a reputation beyond repute
    Dec 2008
    Andalusia,Alabama
    Post How to tell5.3 or 4.8
    If you have vin#s your local GM parts dept. can tell you. I had a list of #s, if I can find I will post them.
    Newbie jarrobin22 is a glorious beacon of light
    Feb 2009
    When you look under the hood there will be a few stickers in the front. One of these stickers should say the the correct info i.e. year, liter size, etc.
    Legend
    adampaul1964 has a reputation beyond repute
    Feb 2009
    Greencastle, Pennsylvania, United States
    Ditto on the VIN# , it will tell you just about everything from gear ratio to paint code!
    Adam
    2005 Z71 Silverado Crew Cab
    previous:
    '97 Chevy Suburban LT
    '94 GMC Sierra SLE
  5. #5
    Jr. Mechanic steves86ta is a glorious beacon of light
    Nov 2008
    Cherry Valley California
    1 Post(s)
    it is the 8th digit of the vin. What year is the truck? This will tell you exactly what it came with because you can not change it. If it is a 2000-2006 and the 8th digit is a T then it is a 5.3, if it is a U then it is a 6.0 a V is a 4.8 and a W is a 4.3V6
    2008 Silverado, 5.3, G80, Extended Cab, California package, 20's, Direct trend motorsports 3" muffler dumped, Volant/CSI cold air intake, 2005 Preadtor Troy Lee Edition
  6. #6
    Jr. Apprentice tgrfn787 is a glorious beacon of light
    Feb 2009
    Quote Originally Posted by steves86ta View Post
    What if it is a 2006 and the eighth digit is a B?
    2006 Silverado 1500 Z71: K&N FIPK, true dual flowmaster 40, superchips cortex, window tint and audio mods, CB, TBS, sprayed liner/box
    1967 c10: frame-up rebuild with crate 350, too much to write
  7. #7
    Apr 2008
    thanks .. hes on his way home from work then ill post the vin..
  8. #8
    Nov 2008
    1 Post(s)
    Quote Originally Posted by tgrfn787 View Post
    I believe that is a flex fuel 5.3 but dont quote me
  9. #9
    Feb 2009
    I figured it out, the B means the L33 5.3 SFI engine, T is for the LM7 5.3 SFI, and Z is for the flex fuel 5.3 with MFI... The difference between the B and T 5.3's is that the B (L33) is rated for 310 hp while the T (LM7) is rated for 295, but both offer 355ft/lb of torque. The power difference comes from the fact that the L33 is the aluminum block version of the LM7, otherwise they are mechanically identical.
    Turns out I have a L33, which I guess is lucky for me because I always assumed I started out with 295 hp.
    This is the website for the 2006 GM vin cards:
    http://service.gm.com/dealerworld/vi.../vincard06.pdf
    you have to have acrobat reader to view them.
    Likewise you can view the vin cards for any 2000-2009 vehicle from this site:
    http://service.gm.com/dealerworld/vincards/
