What bench seat is a direct bolt in a 97 regular cab truck. Will 88-99 work ?
As far as i know all of the regular cabs 1988-1998 have the same floor pan. So any bench should fit as a bolt on. now if you want a 60/40 it will need more holes drilled (not a big deal i did this to put buckets in my s10. What do you currrently have in your truck for a seat? I know in the extended cabs the floor pan is different, i believe the center hump is not so wide thats why 2003 bucket seats will bolt up in 96 and up extended cab trucks. There is a slight possibility that the older benches pre1996 won't bolt up. If you go measure how far the bolt holes are away from eachother i will measure my 89 and you will know for sure if it will fit or not. hope i could be of help
1991 s10 2.8 v6 2wd, lowered 2/2 shaved door handles, pride and joy. Now wreckedtime to fix again
Make room for my '89 silverado
Bookmarks
