Results 1 to 9 of 9
    Legend 1st Synthetics is a name known to all
    Feb 2009
    Nationwide
    Lightbulb Duramax Milage?
    What are all you getting for MPH out there with you Duramax Diesels? Right now I am getting around 14-16 mpg. It's hard for me to tell what potential I have it seems I'm either plowing or towing with my rig.
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Tell us more about your truck. What year, stock, lifted, any mods? I get 17-20 with mine with a 6" lift and 35's because I put aftermarket exhaust and use a programmer.
    Darcy
    Washington State
    Feb 2009
    Nationwide
    Stock wheels and tires, Linex in the bed and on the bed rails, have hidden LED strobes in the headlights and tail lights, and a boss plow. its my work truck. The new '07 1/2 and up all have the DPF and do not get as good of millage as pre DPF. The regeneration uses up a gallon or more of fuel about every tank to clean out the DPF.
    I do have an Edge Juice w/ attitude. Alway ran it stock but just set it on level 1 about a week ago. I bought mostly for the gauge features wile towing or plowing.
    2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
    AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
    Preferred Customers Save up to 30% Click here!!!
    Executive Direct Jobber ZO# 1695636
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Moderator
    Jan 2007
    Yacolt, Washington
    You will find by turning it up a bit it will increase performance as well as milage. My Quadzilla tuner has 6 tunes and I have tried them all and run it on the 70HP tune and get the best mileage.
    Darcy
    Washington State
  5. #5
    Feb 2009
    Nationwide
    I have to look at my turbo down pipe connection. There had been a lot of them leaking and sound like you lose millage if they do. This is only on the LMM. I will try level 1 on the tuner also.
    Order online:
  6. #6
    Feb 2009
    Nationwide
    Talking
    WOW I pais $1.89 yesterday for diesel....
    Order online:
  7. #7
    Newbie Wanderer47 is a glorious beacon of light
    Mar 2009
    Default Turbo Down Connection?
    Quote Originally Posted by 1st Synthetics View Post
    How does one inspect/check this or will dealer etc have to check it?
    Getting about 13 average, towing 5kTT, buzzing around town and some open highway miles
    2009 Duramax, 2500, 2WD, 2100miles.
  8. #8
    Feb 2009
    Nationwide
    I believe there is a bulletin out for"Diesel smell on regenerations" if you call the dealer. Do not say anything about bad mileage. To inspect your self you need to remove the air baffle, and behind the turbo you will see a shield that needs removed. After that you should see the down pipe and be able to tell if there is leaking going on during regen. There would be black soot where the down pipe connects to the turbo. Hope this helped.
    Order online:
  9. #9
    Feb 2009
    Nationwide
    OK I'm at the dealer getting some recalls fixed on my wife's Acadia. I had the service guy look up down pipe on service bulletins and it came up. So if you call just tell them you smell diesel during regen and you did some research and came up with the defective turbo down pipe. This should get them to the correct bulletin.
    Order online:
Similar Threads
  1. Gas Milage
    By chrismx104 in forum Performance & Fuel
    Last Post: 04-03-2010, 11:27 PM
  2. Chevrolet : C5500 Duramax Duramax Diesel Box Truck W/ Lift Gate
    By Steve in forum Chevy Trucks For Sale eBay
    Last Post: 03-18-2010, 12:50 PM
  3. Gas milage effect
    By 97chevz71 in forum Lifted & Offroad Suspension
    Last Post: 08-07-2009, 09:12 PM
  4. duramax fuel milage
    By surfdiver in forum Performance & Fuel
    Last Post: 03-29-2009, 09:27 PM
  5. gas milage???
    By ascalese in forum Performance & Fuel
    Last Post: 02-12-2008, 12:18 PM
