I just bought a 03' Z71 and it has remote start installed but the guy who traded it in to the dealer lost his key fob, how do i tell if it is a factory or an aftermarket one?
It has an antenna on top of the the rear view mirror and has the on/off switch under the dash along with the warning sticker under the hood if that helps any.
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
My mom had a 2000 Cavalier with the GM factory remote start, and it did not have an on/off switch. The dealer system has a very clean and hidden look to it, other than the key fobs you would never have any clue that it had it. My 2001 S-10 has an aftermarket Viper alarm/remote start, and the antennae is mounted on the upper left hand corner of the windshield. My guess is that yours is an aftermarket system, good luck.............AMY
It sounds like you have an aftermarket component. Stock systems don't have the extra antena. Look aound this web site. It might be what you have.
http://www.viper.com/
Trevor - Huntington Beach, CA
2007 GMC 2500 4X4
so dug around under the dash and found the little black box, its a astroflex remote auto starter with keyless entry.
so now i just got to go to a couple of their dealers around town and get some prices
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
do yourself a google search of the name and number on the black box you found. if you dig around enough you should be able to even download the owners manual. I found the owners manual and installation manual for mine...just had to go digging. you could check ebay for a remote and allso programming instructions...good luck
http://astroflex.findlocation.com/results.aspx
put in your zip and it will show you the local delear(s) for that unit![]()
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
If you don't have one, for a French/English version of the manual go to http://www.astroflex.com/modules/Axi...04U-5204U).pdf
Good luck with the new remote!
Are we having fun, yet?
Bookmarks
