Results 1 to 10 of 10
    Legend
    ippielb is a name known to all
    Feb 2009
    Canada
    Default Transfer Case noises
    Yesterday my dad drove me into the city so i could go in to see the doctor, and we took my truck. It was snowing / freezing rain so my dad had it in auto 4wd, and then 4x4 when we got into the city. We turned into the parking lot of the doctors office, and there was a lower pitch noise that kind of sounded like grinding coming from under the truck kind of towards the front of the vehicle. I'm assuming its the transfer case, because it only does the noise when it was in 4x4, it stopped making the noise when my dad took it out of it. Then today, i drove the truck, and we just got around 4 inches of powder snow, and driving down the gravel road 2wd would put me sideways if i got going any speed. So i shifted into neutral going around 60km'h, almost as if i hit the brakes the snow stopped me dead before i could put it in 4x4, so i basically stopped in the middle of the road and put it in 4wd. Then i put it back in drive and it made the grinding noise again. Does anyone have any ideas what could be happening? It never did the noise before, and it just started yesterday when my dad drove it.
    Thanks
    Sr. Apprentice jim1958 is a glorious beacon of light
    Dec 2008
    Findlay,Ohio
    Sounds like you just bought about a $ 1300.00 dollar transfer case, sorry. If you push the buttons going down the road, it ain`t pretty
    Legend
    Feb 2009
    Canada
    Sorry, i fixed my post, it didn't make much sense.
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    As far as I understand it you should be able to **** into 4wd while driving and don't necessarily have to be stopped to do so nor do you have to put it in neutral.
    As for the noise... I really am out of my depths here but my first thought would be about the fluid levels in everything.
    Anyone else..?..
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
  5. #5
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    I wouldn't assume just yet that it's from the transfer case. Transfer case is more in the middle of the vehicle, rather than in the front (but that doesn't necessarily mean much because power train noises have a way of traveling). Where the noise only occurs in 4wd, I'd check those things that are engaged/loaded in 4wd, like front driveshaft u-joints, front diff bearings, CV joints in the axleshafts, etc. I might start by lifting the front end off the ground, crawling underneath, and turning a few things by hand to see if I could pin down where the noise is coming from.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
  6. #6
    Legend
    Feb 2009
    Canada
    I'm going to get the fluid level checked.
  7. #7
    Legend bry2500 is a glorious beacon of light
    Oct 2008
    Gloucester, MA
    I have a similar noise and it was mentioned to me that because I have different manufacturer tires front and rear they are not truly the same size. I get a clunking and slight grinding noise when in 4wd and turning. just throwing another sugestion out there. If I find the post I'll link it for you.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
  8. #8
    Newbie maw454 is a glorious beacon of light
    Feb 2009
    i would check the front end for before wasting time at the transfer. deffently around the cv's and see about the spider gears and fluid levels
  9. #9
    Legend
    Feb 2009
    Canada
    100% sure its the transfer case now. Took it into my shop and got a buddy to listen while i put it in 4x4, he said it's the transfer case. But shockingly it's not making the grinding anymore. It's just making a little louder humm then usual. I'm going to get my transfer case fluids checked out as soon as i can get into the city. Is it bad to use 4x4 right now? Because we just got a foot of snow, and my roads aren't plowed yet.
  10. #10
    Legend
    silveradotrailblazer has a reputation beyond repute
    Dec 2008
    Andalusia,Alabama
    Post transfer case noise
    Transfer case fluid does need to be changed. Check your owners manual for type of fluid you should use.
Similar Threads
  1. Transfer Case
    By tpkamp in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-26-2010, 12:09 PM
  2. Transfer Case
    By pokey in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 05-31-2010, 08:50 PM
  3. Need help with the transfer case
    By mrcheek in forum Powertrain
    Last Post: 04-06-2009, 11:26 AM
  4. 96 transfer case
    By desertratt66@yahoo.com in forum Powertrain
    Last Post: 04-05-2009, 12:17 PM
  5. Which transfer case do I have?
    By mrcheek in forum General Chevy Tech Q&A
    Last Post: 03-27-2009, 04:02 PM
