Page 1 of 3 123 LastLast
Results 1 to 10 of 24
    Legend bry2500's Avatar
    Oct 2008
    Gloucester, MA
    Default Great diagram of Wheel Backspacing and Other Measurements
    Wheel Backspacing and Offset
    Before mounting a set of aftermarket wheels, there are some dynamics involved with fitment that are best to understand first.
    1. Wheel Diameter. This is the diameter of the wheel. Stock wheels are commonly 15 or 16 inch diameter. This dimension is usually in 1 increments (i.e. 15, 16, 17) but some manufacturers offer 16.5, which is rare.
    2. Wheel Width. This is the width of the wheel, measured inside the outer lip of the wheel. This dimension is usually in 1/2 increments (i.e. 7.5, 8)
    3. Wheel Center. This is the center of the wheel in relation to the width.
    4. Offset. The distance from the centerline of the wheel to the face of the mounting surface of the wheel that contacts the hub.
    4.1 Zero Offset. Indicates the mounting surface is at the wheel center.
    4.2. Negative Offset. Indicates the mounting surface is behind (or inboard) the centerline of the rim. This is often found on standard rear-wheel-drive vehicles and on so-called reversed rims. (Diagram below shows negative offset)
    4.3 Positive Offset. Indicates the mounting surface is in front of (or outboard) the centerline of the rim. This is often found on front-wheel-drive vehicles. Stock Tacoma wheels have Positive offset.
    5. Backspacing. The distance from the mounting surface to the inside lip of the wheel. This measurement is closely related to offset (without actually measuring, backspacing is about equal to [Wheel Width / 2] + [Offset] + [about 1/4] ).
    6. Centerbore. The centerbore of a wheel is the size of the machined hole on the back of the wheel that centers the wheel properly on the hub of the car. This hole is machined to exactly match the hub so the wheels are precisely positioned, minimizing the chance of a vibration. This measurement may be critical to clear the hubs of a 4WD.
    7. Bolt Circle. Also known as PCD (Pattern Circle Diameter). The bolt circle represents the diameter of an imaginary circle that goes through the center of the bolt holes. 4x2 Tacoma Bolt Circle: 5 lug on 4.5 PCD; 4x4/Prerunner Tacoma Bolt Circle: 6 lug on 5.5 PCD.
    (Diagram: Alloy Wheel Cross-Section)
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
    Well thats was def informative thanks learn something new every day
    great diagram this will help a lot of people. stickied
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have :great:
    Join the GMTC Facebook Group!!! Join Here
    Oct 2008
    Gloucester, MA
    Hey if I didn't find it I'm sure someone else would have.
    Glad I could help anyone.
    BRYAN
    8.1L Vortec
    43,000 miles
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Great information!
    Chevy Truck Parts
    Darcy
    Washington State
    WOW! That is an awesome write up, I printed this off and gave it to my boyfriend who thinks he knows it all when it comes to this kind of stuff. Thanks very much, this will have a special place on the garage wall right next to the picture of my truck.
    Sr. Mechanic
    May 2009
    Austin Texas
    Quote Originally Posted by bry2500 View Post
    Good information since I am currently looking at 20" wheels for my 2009 GMC!! Thanks!
    well that cleared up some muddy water...
    The diagram is what really did it for me. Thanks.
    www.youtube.com/ippielb
    Sr. Mechanic larryleeUSN's Avatar
    Jun 2009
    Now stationed in Mayport,Florida
    Default does any one know?
    does anyone know the stock offsetting and back spacing of the stock 06 silverado rims? not the Z-71 rims the bullit hole style rims?
    Lawrence Lee,United States Navy, Engineering.
    2008 Silverado CC. Z71 4x4. leveling kit on with exhaust hopefully putting on soon
  1. In need of measurements from NBS Silverado
    By ThatSilverStepside in forum Chevy Truck Accessories
    Last Post: 06-15-2010, 11:33 PM
  2. wheel and backspacing question
    By bacol14 in forum Lifted & Offroad Suspension
    Last Post: 06-09-2010, 01:37 AM
  3. 07 leveled wheel backspacing
    By rangercliff in forum Lifted & Offroad Suspension
    Last Post: 05-25-2010, 08:11 PM
  4. lifted s10 or sonoma wheel backspacing
    By black98noma in forum Lifted & Offroad Suspension
    Last Post: 05-15-2010, 11:27 PM
  5. wheel backspacing help!
    By tallhoe in forum Lifted & Offroad Suspension
    Last Post: 05-22-2009, 04:21 PM
