Results 1 to 4 of 4
    Jr. Apprentice drillRR is a glorious beacon of light
    Feb 2009
    Default Stereo Amp Ground
    Sup! New to the site. Trying to hook up a amp and sub in my 07 Silverado. Cannot get a good ground from amp anywhere in the back seat area. Only way speaker will play is if you rub the amp ground across a bolt going to the body, when it sparks the speaker will play momentary and then shut off. If we fasten the ground securely it will not play at all. Tried 2 different amps with same result and even ran a ground all the way to the battery with same result. GETTING FRUSTRATED! Any ideas?
    Sr. Apprentice Chevy Newby is a glorious beacon of light
    Feb 2009
    Cleveland, OH
    Default very strange
    I use to work at a shop for 5 years as a mobile audio/video installer. the bolt that you are attaching the ground wire to ,have you scraped the paint from around the bolt? is the amp maintaing power or going into protect mode when you do strike the ground wire accross the bolt? what brand and type of amps are you using? do you have the ground wire crimped into a connector?...are you using the factory head unit?
    Legend cascott325 is a glorious beacon of light
    Aug 2008
    Lawrenceburg, Kentucky
    you want to keep the ground short as possible, but dont make it tight, you do want some slack, but not much. i think i took out one of the nuts on one of my seat belts, and scraped the paint away from under it then tightened it back down. you can put some di-electric grease to help out with it. but you really have to get that paint away for good contact. use a flat screwdriver and some steel wool or sand paper.
    2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
    extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
    reman tranny @ 130k miles
    Chris
    Feb 2009
    Thanx guys, we found the prob. Two strands of wire were touching in the RCA adaptor we installed behind the factory radio. @!#$%$ Thanx again for advice!
Similar Threads
  1. ground affects
    By express conversion in forum Chevy Express Forum (GMC Savana)
    Last Post: 06-12-2011, 01:44 PM
  2. Ground Clearance 2009 Sub
    By Room 055 in forum Lifted & Offroad Suspension
    Last Post: 03-29-2010, 11:33 AM
  3. Pants on the ground! Pants on the ground!
    By Steve in forum General Photos & Videos
    Last Post: 02-01-2010, 11:48 PM
  4. 03 chassis ground location?
    By SoundZman in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-04-2009, 01:08 AM
  5. Ground Force 2/4 Kit with Shocks
    By airdeano in forum For Sale & Wanted to Buy
    Last Post: 07-15-2008, 11:39 PM
