Here's the low down.. my rear driveshaft is royally done for. I have a 2000 silverado 1500 series z71 ext cab. I found a replacement on craigslist but the vehicle is a 2000 silverado 1500 series 2wd ext cab. So.. is there any difference between a rear driveshaft on a z71 and 2wd silverado ext cab?
2000 Silverado ext cab1500 Z71
Have:
-K&N
-SPR-17S Fronts with 100RMS watts to each
-Billet Grill
-Bedliner
-Catback Flowmaster Exhaust
-CDA-9884 Head unit w/ iPod hookup
-2 KFC-W3011 subs (seperate boxes 1 cu ft air space each) powered by a KAC-9104D 900 watt RMS monoblock amp
-SPR-57C rear speakers
-Door dings
-Leveling kit (2.5" torsion keys)
Want:
-6" Suspension Lift
-35" tires (maybe 38s)
-HID/projector headlights
-Headers
-Programmer/Tuner
I would assume that the Z71 shaft would be better built considering what you do with a Z71 vs a 2WD. Not sure though I am sure someone will know
www.myspace.com/teamimageracing
www.myspace.com/brotherspolish
2002 Silverado
5.3L
Corvette Servo
Spectre Air Intake
MSD 8.5mm Super Conductor Wires
AC Delco Iridium Plugs
Flowmaster 40 Series
Alpine Head Unit
Next Mods
2" Lowering Shackles
Loud Mouth Grill
Have:
-K&N
-Billet Grill
-Bedliner
-Door dings
Want:
-6" Suspension Lift
-Headers
-Programmer/Tuner
I may be wrong but the Z71 driveshaft is going to be shorter because of the transfer case!
Adam
2005 Z71 Silverado Crew Cab
previous:
'97 Chevy Suburban LT
'94 GMC Sierra SLE
Yeah the 4x4 drive shaft is shorter because of the transfer case and I am almost positive it stronger as well so to answer your question NO the 2wd shaft will not work.
Z71 is mostly a cosmetic package, it has better shocks and different spring rates from no Z71 trucks but for the most part your paying more money for shiny stickers.
The driveshaft in question is the same part# for a Z71 or a non Z71 truck of the same body style, i.e excab, single cab.
A driveshaft from a 2wd truck wont fit your 4wd truck, it's a few inches to long because as someone pointed out the transfer case.
You need a driveshaft from a 4wd excab truck, thats the only one that'll fit.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
Bookmarks
