Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    Jr. Apprentice Air Force One is a glorious beacon of light
    Jan 2009
    Default What Transmission do I have
    1990 Chevy Cheyene 1500, 4 speed automactic..I've been told that this transmission is a 4L60E, BUT my Haynes auto manuals says "Beginning in 1991, an electronically controlled transmission, the HYDRA-Matic 4L80-E was installed in some vehicles" ??? Do do I have a 4L60 or 4L60-E? The 4L60-E are not equipped with a throttle Valve (TV) cable assembly. This 1990 chevy truck has a 305 Engine, and when it goes from first to second it has to rev up before it shifts into 2nd. It DOES get better when it warms up some. I put a new filter and oil in it already, and I also put a quart of LUCAS TRANS OIL in it as well...any advise of what I should be looking for or doing? Thanks for your look and advise...AF1
    Jr. Mechanic k.daddy1 is a glorious beacon of light
    Jul 2008
    Bluegrass Country
    You have the 4L60, the beefed up version of the 700R4. The 4L60E didn't get put into trucks until the end of 94 I believe.
    Sr. Apprentice BBC4EVER is a glorious beacon of light
    Mar 2009
    Indy
    I agree, I believe the 4L60. How many miles are on it? There is a shift silenoid for 1-2 and 3-4 on the back side of the valve body (in the pan). I'm not a trans expert, but have serviced quite a few of my own. I don't know how that trans is controlled (cable or vacuum). Make sure the fluid level is spot on. If it's off (especially too full) it will really mess up the shifting and the trans itself.
    Jr. Apprentice OleBlue93 is a glorious beacon of light
    Jan 2009
    troy
    Default transmission
    i have a 93 silverado 2500 light duty with the six lug axles and mine has a 700r4. count the pan bolts the 4l60e is a newer version like they said above but its electronical it has the same pan as the 700r4
    4l80e has 17 bolts
    700r4 &4l60e has 16 bolts
    BRIAN AVERITT
  5. #5
    Jan 2009
    This trans has 130,00 on it. What would you recommend that I check? Has oil changed + Filter..its shifts hard going from 1st to 2nd. thanks for your help
  6. #6
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    The 4L60 is in fact the 700R4. Same same. The 4L60E is electronically controlled as is the 4L80E. The 4L60E was introduced in 1990.
    Jim
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  7. #7
    Feb 2009
    Reno, Nevada
    I sent that post off before I was finished. I wanted to say the 700 or 4L60 models are cable controlled and the E's are controlled by an EPC solenoid.
    If your 4L60E starts shifting hard on the 1-2 chances are it has a P1870 code stored in memory. This is a common torque converter slip code. This code may or may not turn on the check engine light. Best way to tell is to scan the computer for codes. If there are no codes then another thing that can cause a harsh 1-2 shift is a broken accumulator spring. These springs are very easy to change once the pan is removed.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  8. #8
    Legend Crawdaddy has a reputation beyond repute
    Feb 2007
    1 Post(s)
    In a 1990 C/K with the 305, you SHOULD have the 4L60E. They introduced the 4L60E in either 89 or 90. However, if it has the 700R4 and the throttle valve cable in improperly adjusted, the transmission will shift weird and it WILL fail quickly. However, it sounds like you may have valve body issues assuming it's a 700R4. On my 700R4 I had a freshly rebuilt transmission from what I now know is a lousy rebuilder and there was a spring or something in the valve body that was not right. I replaced all the springs with a shift kit and that fixed the issue and gave me a slightly more agressive shift pattern.
    Christopher
    1991 Chevy Suburban 1/2 ton 2WD w/ chevy SBC 350-3/4 ton drivetrain upgrade w/4.10 gears 194K miles
    2005 Saturn ION-2 Stock 200K miles (In 6 years...ouch)
    1982 Bronco, 1993 Bronco, 1971 M35A2 Deuce and a Half
  9. #9
    Jul 2008
    Bluegrass Country
    700R4 introduced in 1982
    4L60 introduced in 1990
    4L60E introduced in 1996
    4L60E was originally introduced in 1995 with a 13 pin electrical connector, then in 1996 was changed to a 11 pin connector. That's why the 95 chevy vehicles with the 4L60E can only be changed out with a tranny from a 95. Check the books if you don't believe me.
  10. #10
    Sr. Apprentice CJlambertz71 is a glorious beacon of light
    Oct 2007
    georgia
    ok i have a question about my transmission, i cant tell if its a getrag trans or a new processor trans
    i have a 1991 k1500 z71
    its a 5speed manual
    and the number on it is GM8672286
    1991 k1500 z71, 3-inch body lift with 315x75 mickey thompson atz. all new xplod speakers to replace old speakers. brand new 5.7 liter 350 with flowtech midlength headers and true duals into one x pipe muffler
Similar Threads
  1. Transmission Pan
    By elishaman in forum Powertrain
    Last Post: 05-12-2010, 02:51 PM
  2. transmission
    By Bill1996 in forum Powertrain
    Last Post: 09-11-2009, 03:26 PM
  3. transmission
    By stepsideoh in forum Powertrain
    Last Post: 11-12-2008, 11:19 PM
  4. Replies: 0
    Last Post: 06-08-2007, 12:53 PM
  5. Replies: 0
    Last Post: 06-08-2007, 10:20 AM
