I just lifted my 2003 2500HD Silvie, Lifted about 2.5" over stock height. I have been looking everywhere to find a recommendation for tire size, but with no definite luck. So what size tire can I run? After doing some calculations going from the 31.6" stock to a 35" upgraded will add 1.6" (center to fender on all measuring angles) What has/does everyone else run (ran)? stock wheels and tires as of now.
2004 Silverado 2500 HD 6.0L,Diablo Tuner, K&N, 9" custom suspension lift, 2" body lift 3" cowl induction hood, 37" Toyo M/T's 18" incubus wheels. Comp Cams 212/218 lsa 114, E-fan. Dual shock kit, Es bushings, moog chassis front end.
are you still going to be running stock rims?
PETE
95 GMC Sierra 2500
3" Body Lift, 33" Goodyear MTR's
5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
Sold :(
1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
Contact this GMTC Moderator for any problems or questions you may have
Join the GMTC Facebook Group!!! Join Here
Remember it is not only the diameter of the tire that will play into effect. The width will be the issue during turning, also if you change rims the offset will further play a big factor. It is a math nightmare but a little time with a calculator beats trimming parts.
BRYAN
"IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
02' Avalanche 2500 Onyx Black
8.1L Vortec
43,000 miles
if you run a 17" rim, I would run a 285/75R16 on a stock rim or a 285/70R17 on an aftermarket rim
PETE
95 GMC Sierra 2500
Sold :(
No intensions of hijacking this thread but I have a question.
Do you have to change the tire/rim size or can you stay stock? I'd like to lift mine about 2-3 inches but would rather not change out the stock wheel and tire size. I'm mostly a highway driver and would be doing it strictly for looks.
Never mind, found this on www.Roughcountry.com
The taller a vehicle is, the easier it will roll. Offset, as much as possible, what is lost in rollover resistance
by increasing tire track width. In other words, go "wide" as you go "tall".
PETE
95 GMC Sierra 2500
Sold :(
Bookmarks
