Results 1 to 6 of 6
    Jr. Mechanic ChevyFarmKid is a glorious beacon of light
    Mar 2008
    Chelsea, MI
    Default 2003 silverado 1500 Check Engine Light
    On my 03' Silverado 1500 with a 5.3 liter, my check engine light is coming on and kicking out 2 codes, p0171 and p0174. I have already put a new mass air plow sensor in, What next?
    Newbie doddelectric is a glorious beacon of light
    Feb 2011
    sulphur springs tx
    i have a 2003 4x4 4.8 i am having the same problem ! if any one has the solution please let us know
    Former Member COLIN DE is a glorious beacon of light
    Feb 2011
    If the light comes back on after sometime then go to either autozone (US) or parts source(Canada) and ask them to hook up your car to their portable code scanner (this is usually a free service). Once the scanner tells you the code, google it and then you would know the problem.
    Legend
    mfleetwood has a brilliant future
    Jul 2010
    Denver, CO
    Quote Originally Posted by doddelectric View Post
    P0171/P0174 A lean fuel condition can be caused by:
    * Low fuel pressure due to a weak pump or leaky(use a fuel pressure gauge to check fuel pressure at idle)
    * Dirty (try cleaning the injectors)
    * Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
    * Leaky EGR valve. (Check operation of EGR valve)
    * Leaky PCV Valve or hose. (Check valve and hose connections)
    * Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
    Mike (Denver, CO) - 2008 Sierra 1500 Z71 SLE 5.3L 4WD
    SUSPENSION: Rancho 4" Suspension Lift; Rancho RS9000XL Shocks; Rancho Skid Plates; Rancho MyRide Wireless Shock Controller;
    TIRES:
    BFG All Terrain 315/70/17
    DRIVE TRAIN: 4.56 Gears; Detroit TrueTrac Differential
    PERFORMANCE: DiableSport Predator Tuner; Custom Tuned by Diablew; Magnaflow Exhaust; AFE Cold Air Intake
    ELECTRONICS: Kenwood DNX6180 Touchscreen; Subthump box w/10" Kicker; Driver Information Center (DIC); Rear View Camera
    ACCESSORIES: Westin Brush/Grill Gaurd; Westin Nerf Bars; Truxedo Tonneau; 20% Tint; Tow Mirrors w/Heat & Signals
  5. #5
    Feb 2011
    sulphur springs tx
    HOW much pressure should i have at idle on fuel pump
    DODD
  6. #6
    Newbie cshoule is a glorious beacon of light
    Feb 2011
    Marius,MB
    I've seen this before, the one i worked on gave simular codes, all along it was the harness at the front of the intake.the cover will have to be taken off to see. a wire came off the pin at bulkhead plugin on that one. a vortec should have around 60psi of fuel pressure.
Similar Threads
  1. Check Engine Light on a 07 Silverado?
    By malibuman82wgn in forum General Chevy Tech Q&A
    Last Post: 04-29-2010, 02:24 PM
  2. 08 Silverado Check engine light
    By 1S1K in forum General Chevy Tech Q&A
    Last Post: 01-11-2010, 08:21 PM
  3. 2003 silverado check engine light
    By txsilverado in forum Powertrain
    Last Post: 12-28-2009, 06:57 PM
  4. 03 Silverado Check Engine Light
    By ChevyFarmKid in forum General Chevy Tech Q&A
    Last Post: 01-23-2009, 05:40 PM
  5. 2000 silverado 4.3 check engine light.
    By rvaddict in forum General Chevy Tech Q&A
    Last Post: 11-19-2008, 01:22 AM
