Results 1 to 2 of 2
    Exclamation Thinking Of Changing Your Tranny Fluid Yourself???
    Here are some easy to follow instructions to help guide you along in your project.....
    http://www.amsoil.com/faqs/atf_and_f...pdf?z0=1695636
    CLICK HERE With Any Questions...
    Scott
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Thumbs up AMSOIL Transmission Fluids...
    Q: Do you w ant to protect your transmission?
    A: Use AMSOIL Synthetic Transmission Fluids!
    AMSOIL offer a full line of transmission fluids to meet you needs.
    Clich here for more information. Click here to contact me.
    Synthetic Universal Transmission Fluid
    AMSOIL ATF provides automatic transmissions, power steering units and hydraulic equipment with excellent lubricating protection and better performance over a wider temperature range than conventional automatic transmission fluids. Outperforms petroleum fluids in low temperature fluidity.
    Manual Synchromesh Transmission Fluid 5W-30Designed for manual transmissions and transaxles with synchromesh systems that require light viscosity, non-extreme-pressure fortified oil. Additive technology provides proper friction characteristics for smooth shifting. The ultimate in gear and bearing protection & outperforms motor oils in manual transmissions.
    Manual Transmission & Transaxle Gear Lube 75W-90
    formulated specifically for maximum protection in the most demanding manual transmission and transaxle applications where an extreme pressure GL-4 gear lube is specified, including those where high horsepower/high torque engines and towing or heavy loads increase transmission stress.
    Super Shift Racing Transmission Fluid SAE 10W
    Outstanding performance in high-performance, high-horsepower vehicles. Formulated without friction modifiers and viscosity improvers for positive clutch pack engagement and stable viscosity. Prevents slippage and lowers heat. Recommended for racing and street performance automatic transmissions.
    Torque-Drive Synthetic Automatic Transmission Fluid
    Engineered specifically for the Allison TES-295 transmission fluid specification. Replaces Allison/Castrol Transynd® fluid. Excellent protection in temperature extremes. Ensures consistent, smooth clutch engagement over the life of the fluid and controls clutch glazing and elongated shift times.
    Synthetic Powershift Transmission Fluid SAE 10W, 30W, & 50W
    Formulated for heavy-duty powershift transmissions. Provides outstanding friction performance for enhanced clutch engagement. Prevents slippage and glazing. Shear stable and anti-wear fortified. Resists high-temperature oxidation, varnish & sludge formation. Superb cold-flow properties.
    Order online:
  1. Changing transfer case fluid
    By Silverado Junkie in forum Maintenance & Upkeep
    Last Post: 07-31-2010, 10:22 PM
  2. how many qts of fluid in a tranny pan?
    By bigdaddy77084 in forum GM Powertrain
    Last Post: 02-26-2010, 12:18 PM
  3. changing tranny fluid
    By IThurstSObad in forum Chevy C/K Truck Forum
    Last Post: 12-26-2009, 12:35 AM
  4. What tranny fluid to replace Dexron III
    By IrishBrewer in forum GM Powertrain
    Last Post: 03-05-2009, 11:28 AM
  5. Tranny Fluid
    By NRC34 in forum GM Powertrain
    Last Post: 12-31-2008, 07:25 PM
