I found a nice looking set of wheels and tires but they are 15" wheels. Will those fit on my 99 Silverado or are those going to be too small?
99 Silverado Z71 4.8
2" Suspension lift (Add-a-leafs and leveling keys)
Long tube headers with 3" offroad Y-Pipe
Volant Cold Air Intake with Ram Air Intake Tube
Jet Mass Air Flow Sensor
Diablosport Predator Tuner
Previous Truck:
97 Suburban K1500
3" Body lift
2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
35" Yokohama M/T's
K&N Intake
Airraid Throttle Body Spacer
Hypertech Programmer
Dual Flowmasters
I've got a set of 15x7's for my '98, and they fit just fine. Mine has the 11 inch brakes, and there basically is no room to spare. If your '99 has the same 11 inch brakes as my '98, you'll be fine. If you have bigger brakes, then 15's won't fit.
'98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
'92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
"My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
I think 99 and up have bigger brakes so I dont think a 15 inch rim will work on it
I wouldnt go smaller than the stock size. they are on there for a reason
PETE
95 GMC Sierra 2500
3" Body Lift, 33" Goodyear MTR's
5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
Sold :(
1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
Contact this GMTC Moderator for any problems or questions you may have
Join the GMTC Facebook Group!!! Join Here
I think your right dickie, its the same with vans. you can't fit a 15" wheel on a 2004 express. because they use bigger brakedisks front and replaced the backdrums by disks also. and nowing that vans always are some years behind on trucks technologywise. i figure it will be that.
VANNERS CREED.
I dont try to explain why im a Vanner
for those who understand no explanation is necessary
for those who dont no explanation is possible.
Previous Truck:
97 Suburban K1500
3" Body lift
35" Yokohama M/T's
K&N Intake
Dual Flowmasters
I think that's a possibility. My '98 came with 16 inch wheels from the factory, and yet the 15's fit just fine. There is no inherent advantage to the 15's, so there's no harm in summarily dismissing the idea of going a size smaller, if you aren't sure. I guess it depends on how appealing this particular set of rims is to you.
If you can, try before you buy. If it fits then great if it doesn't well then see if you can't find that same style in a 16". Good luck
[/SIGPIC]07 Silverado LS factory 20's, spray in bedliner, in-bed cargo managment system, matching tint on front windows, K&N CAI, and Hypertech Max Engery Tuner and yet even more mods to come.
NO!! they will not fit, just because a 98 comes with 16s and 15s fit is completely irrelevant. They are 2 COMPLETELY different body styles of truck unless you have a 99 classic. If you have a 99 classic then the 15's should fit.
I think if you have HD trailer package they wont fit because of brakes.
Bookmarks
