Results 1 to 4 of 4
    Newbie rebel4wd is a glorious beacon of light
    Mar 2009
    Default Th350 to 700 swap?
    Hello all, new to the forums. My buddy has an 86 GMC 2500 van with the 350 and a TH350 with 9" tailshaft. The trans. just went out, and we cannot find a used long tail Th350 anywhere. Heres my question- can we swap in a 700R-4 out of a similar van like 84-87 with the driveshaft and vacuum switch for the lockup converter? Any other mods we need to make to speedo/ tv cable? Thanks for any input.
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by rebel4wd View Post
    You can swap in a 700. You may need a new flex plate unless the one you have is drilled for the 700 converter. You will also need the dipstick, dust shield, and TV cable. The drive shaft may or may not work depending on the length of the yoke. Sometimes the drive shaft will just drop in and other times you will need to have it lengthened. The shifter <prndl> will be missing OD but thats no big deal.
    Keep in mind the early 700's have governor controlled lock-up and later 700's do not. If you get a later 700 without the governor controlled lock-up you will need a conversion kit to make the lock up come on in 4th gear. Otherwise without the governor control lock up you will have lock up right on top of 2nd gear. The kits are available on line and some come with the vacuum switch which is desirable. You may also need an adapter on the carb where the cable attaches in order for the TV geometry to be correct. Some Quadra-Jets have the correct geomerty and some do not. Most other carbs need this adapter. Edlebrock and others make a kit.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Mar 2009
    Thank you for the info! Do you know what year they switched over from the governer controlled lockup? Thanks.
    Feb 2009
    Reno, Nevada
    It was mid 87 If I remember correctly.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
Similar Threads
  1. th350 to 700r4
    By 1977GMCck25 in forum Chevy C/K Truck Forum
    Last Post: 05-28-2010, 10:38 AM
  2. th350 speedo
    By bryanchevytruck in forum Powertrain
    Last Post: 05-13-2010, 12:40 PM
  3. Replies: 0
    Last Post: 12-05-2009, 04:20 PM
  4. Th350
    By ekacpuc in forum Powertrain
    Last Post: 09-11-2009, 07:54 PM
  5. rear end swap or gear swap
    By rmagni in forum Powertrain
    Last Post: 08-18-2009, 08:42 PM
