Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
    Jr. Engineer mjalstad is a glorious beacon of light
    Jan 2009
    Rochester, MN
    Default 2" Leveling kit and Add-a-leafs
    I started installing my leveling kit today. I got the rear done but did not have time to do the front. I got a Tuff Country kit from suspensionconnection which included torsion bar keys for the front and an add-a-leaf for the rear for just under $200 after shipping. I figured I better start in the rear since if I didn't have time to finish, it would look a lot better to have a jacked up rear than a jacked up front. It was a little bit of a hassle and required a lot of elbow grease but I got it done in abut 3.5 hours in my garage. I made the mistake of thinking I could do it one side at a time, so I jacked up the passenger side and disconnected the rear U-bolts, got the leaf pack loosed up and started clamping the leaf pack with the new leaf back down when I realized there would not be clearance to put the aligning bolt in from underneath without doing the other side at the same time. So I wasted about a half hour trying to make it work because I only had one jack but I ended up using a big block of wood as a small jackstand while I moved the jack around and got the other side going. I only had one other hang up and that was removing the bolt from the driver's side shock, but after hammering, heating, PB blastering and wrenching I got it out after about a half hour. Afterwards, it looks awesome, I cannot wait to get the front done! It went from looking like a normal everyday half ton truck to looking like a manly heavy duty truck, well the rear half anyways. I have some before and after pics that I will have to get posted up and will add some more when I get the front done. I luckily had sme 6" C-clamps which I thought would be excessively big because the stock leaf pack is only a few inches thick but when you add the curve from the new leaf, a 6 inch is neccessary to get it in to place. I would definitely recommend this to anybody looking for a little more agressive stance, I think it's by far the best bang for the buck for $250 (after cost of parts and alignment), even better than an intake or programmer.
    99 Silverado Z71 4.8
    2" Suspension lift (Add-a-leafs and leveling keys)
    Long tube headers with 3" offroad Y-Pipe
    Volant Cold Air Intake with Ram Air Intake Tube
    Jet Mass Air Flow Sensor
    Diablosport Predator Tuner
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
    35" Yokohama M/T's
    K&N Intake
    Airraid Throttle Body Spacer
    Hypertech Programmer
    Dual Flowmasters
    Legend
    Pete95Sierra is a name known to all
    Jan 2008
    Morristown, NJ
    nothing ever seems to go perfect while wrenching haha, be sure to post pics!
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have
    Join the GMTC Facebook Group!!! Join Here
    Jan 2009
    Rochester, MN
    Well here is before and after the Add-a-leafs. Hopefully I will have time tomorrow to get the front done. I must say that driving to and from work tonight, the add-a-leafs themselves definitely tightened up the suspension a little bit. I wouldn't say the ride is too hard though, I like it a lot more, there's not as much body roll now. I do kind of fell like I am riding at an angle though, I almost had to recline my seat back another notch.
    Update, I added the third pic here of the AALs and the keys on. 1st pic is stock, second pic is only the AALs, and the 3rd pic if the AALs and the Keys.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	2098   Click image for larger version
Name:	After AAL 1.jpg‎
ID:	2099   Click image for larger version
Name:	After AAL and Keys (2).jpg‎
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    35" Yokohama M/T's
    K&N Intake
    Dual Flowmasters
    Legend
    adampaul1964 has a reputation beyond repute
    Feb 2009
    Greencastle, Pennsylvania, United States
    looks awesome, can't wait to see the front, I'm especially interested to hear how the installation went since I have a set of keys that I'm going to put on my truck.
    Adam
    2005 Z71 Silverado Crew Cab
    previous:
    '97 Chevy Suburban LT
    '94 GMC Sierra SLE
  5. #5
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    Looking good, now your starting to look like a 2500HD!
  6. #6
    Jan 2009
    Rochester, MN
    Well, I tried to get the keys in today and I failed. Autozone didn't have a 2 jaw puller so I went to Sears and got a 7 ton 2 jaw puller for only $40 so I thought things were going my way since I figured it would be a lot more than that. Unfortunately when I got to the step of "tap the torsion bar forward so the key drops out, it would not slide forward. I looked at where it connects to my lower control arm and it is twisted in the socket so it won't move freely (kind of like when you use a socket that is just a hair too big for the bolt and it twists in there just a bit and the bolt gets stuck in the socket). So I think I am going to have to remove the crossmember and hopefully that will do it but I didn't have the right size wrench to get the crossmember off so it will have to wait until another day.
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    35" Yokohama M/T's
    K&N Intake
    Dual Flowmasters
  7. #7
    Legend MWright936 is a glorious beacon of light
    Mar 2008
    Hallsville, TX
    It's never as easy as it sounds, lol! I know that from experience (installing coil spring spacers). Good luck getting it finished up!!
    Matt
    Hallsville, TX
    2005 Silverado 1500 LS Crew Cab 5.3L 2WD
    K&N FIPK II
    Magnaflow Exhaust
    Hypertech Max Energy Programmer
    Suspension Leveling Kit
    Putco Element Window Visors
    Carriage Works Billet Grille
    TruXedo TruXport Tonneau Cover
  8. #8
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    That sucks, I can't even count on all my fingers and toes how many things I have bought that supposedly "bolt right on" But you will get it working I know it, your ambition to finish the truck will help you a lot. Either that or your going to have to ride with the seat leaned back all the time!
  9. #9
    Legend
    Feb 2009
    You're not exactly filling me with confidence..... I have read that you can tap the torsion bar towards the rear of the truck in order to free it up, maybe thats worth a try, good luck I'm sure it will all come together!
    Adam
    previous:
    '94 GMC Sierra SLE
  10. #10
    Master Mechanic CarpenterGuy is a glorious beacon of light
    Jul 2008
    Leeds, Alabama
    i've been wanting to do what your doing. i've been looking at 2" leveling keys in the front and add a leafs in the back. make sure to put up some pics after you've got the full thing put togather!
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    I'll keep my money, guns, and freedom. You keep the Change.
Similar Threads
  1. Replies: 29
    Last Post: 06-14-2011, 10:00 PM
  2. ccm 2.5" leveling kit
    By wolfrivercc in forum For Sale & Wanted to Buy
    Last Post: 08-25-2010, 01:13 AM
  3. Its done - 2" RC leveling kit
    By z3ro in forum Lifted & Offroad Suspension
    Last Post: 03-29-2010, 08:32 PM
  4. 2" Leveling kit and AAL
    By Okimaw in forum Chevy Truck Accessories
    Last Post: 03-03-2010, 08:50 AM
  5. 06 silverado ls 1500 2wd 4.8 "leveling the front"
    By johnsstart in forum Chevy Truck Accessories
    Last Post: 01-31-2009, 05:10 AM
