Results 1 to 8 of 8
    Jr. Apprentice bigblue89GMC is a glorious beacon of light
    Mar 2009
    Virginia
    Default Dana 44 gear swaps
    I was wondering if a ring and pinon set for a jeep d44 will fit in a full-size d44?
    and will a rear gear set fit in a front axle? Thoughts?
    1989 GMC Sierra 1500 6" lift 35x12.5x15 bfg m/t, not on the road anymore but will be back soon!
    2005 Jeep Wrangler X, 31x10.50 bfg a/t, 15x8 soft 8's
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    That all depends on the ratio. The carriers are different for some gear ratios. The front and rear gears are usualythe same.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Legend 95CTburb19 is a glorious beacon of light
    Apr 2007
    Umass / Newtown CT
    hmmm I would think that the center section of the axle would be the same, and just the actual length of the axle tubes would be the only thing different. So I would think that they would be the same, but I am not 100% sure. Hopefully someone will chime in.
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    Mar 2009
    Virginia
    Quote Originally Posted by Jimmiee View Post
    I have a front axle out of a 88 or 89 1500 suburban, I assumed it has a 3.42 ratio but i havn't counted the turns yet. I'm going to 4.10's, which is what i did in the rear of my 10 bolt that had 3.42.
  5. #5
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by 95CTburb19 View Post
    The center sections are all the same. The carrier where the ring gear bolts on is different. I believe the break is at 3.73. but don't quote me on that. The point is there are 2 carriers. One for low gears and one for higher gears. The reason is low ratio pinion gears have fewer teeth than high ratio pinion gears so the ring gear needs to be positioned closer to the center line of the differential. Clear as mud?
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  6. #6
    Mar 2009
    Virginia
    So, if I found a jeep axle with 4.10 gears I could take out the gears and carrier and put it into my chevy axle.
  7. #7
    Feb 2009
    Reno, Nevada
    Yes you could as long as it's not a real old Jeep. Some of the older 44's were a little different. The easiest way to be sure is check the part numbers from the Dana site or Randy's Ring and Pinion site.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  8. #8
    Mar 2009
    Virginia
    Ok i'll do that. Thanks a lot!
Similar Threads
  1. Engine Swaps? 99 silverado
    By 99silv53 in forum General Chevy Tech Q&A
    Last Post: 03-25-2010, 09:43 PM
  2. Spindle Swaps
    By udderchaos in forum Lifted & Offroad Suspension
    Last Post: 01-30-2008, 10:31 AM
  3. gas to diesel engine swaps worth it?
    By Brian's 97 in forum Diesel & DuraMax
    Last Post: 08-05-2007, 04:38 PM
  4. I might be able to get a Dana 60
    By Crawdaddy in forum Powertrain
    Last Post: 08-03-2007, 10:08 PM
  5. Who swaps out Snow Tires in the winter?
    By Steve in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-15-2007, 09:04 PM
