    Default Coolant Temperature too low? Check Engine light..
    Hey,
    I have a 2003 silveardo 4x4 longbed.
    the check engine lights keep coming on everyday after i reset it. Its throwing a code saying the coolant temperature went to low? or something like that, It is really cold out but obviously should not be throwing that code. Any ideas how to fix it?
    I was told the truck may of had a new radiator put in it, could it be a sensor that wasnt property put back on?
    thanks!
    How does your heater work? If your thermostat sticks open the coolant temp can bee too cool on cold days. Another possibility is there's air trapped in the system around the coolant temperature sensor. Or it just may have a bad connection at the temperature senso,r or just a plain old bad sensor. The best way to see what's going on is with a scanner.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Quote Originally Posted by Jimmiee View Post
    Ditto. Thermostat or air pocket. What code number is it kicking out?
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Master Mechanic daddytech's Avatar
    Mar 2008
    Portland TN
    I would say it's air, try this from cold take off your cap, start the truck and keep adding coolant until it no longer bubbles up once the truck is running and the coolant level isn't going down any longer and just before the truck gets totally warm fill it to the very top and put the cap back on and see if that doesn't change things for you. Oh yeah and make sure your reservoir tank is full to the full cold line too that makes a difference also.
    Sr. Apprentice lube70's Avatar
    Northern NJ
    Default code
    code should be a p0142, not able to reach operating temps in predetermined time. Thermostat is going bad. Also, flush the coolant. Dexcool ( older version ) is known to cause issues in past models.
    Don
    Shouldn't have been a sensor removed when the radiator was replaced. I would say and air pocket or more than likely a stuck open thermostat. There should be a cooling system bleeder screw on the top side of your cooling system somewhere. I think it is on the thermostat housing on my GP and truck. Crack it open once your coolant gauge is up a little and see if you get any air out. If thermostat is stuck open and you get a new one .... I would get OEM on this. Not all thermostats are created equal.
    02 Chevy Suburban 1500, 4:10 Difs, Stock for now.
    02, CC, LB, 4x4, LB7, 145K Miles, EFI Live Tuned by Nick at Duramaxtuner, Banks Ram-Air w/ superscoop (Plate Removed), Banks Big Head, AirDog 100, Pillar Gauges, 16x8 Eagle wheels, 285 BFGs, Bilstein 5100's, Ride Rite Air Bags 5" Exhaust, 4" downpipe, Prodigy Brake Controller, Goose Neck.
    02 Grand Prix GT.
  1. Check engine light on.
    By Andy7 in forum Performance & Fuel
    Last Post: 07-16-2010, 01:26 PM
  2. check engine light
    By eightbol21 in forum General Chevy & GM Tech Questions
    Last Post: 07-11-2010, 10:07 PM
  3. Check engine light came on????
    By vncj96 in forum General Chevy & GM Tech Questions
    Last Post: 05-12-2009, 10:27 PM
  4. Check Engine Light
    By RAM717 in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 10-17-2007, 04:24 PM
  5. check engine light
    By ss_silverado_phoneix99325 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-04-2007, 08:57 PM
