i have a 2002 yukon denali and its the same color has the one in the pic..im looking to do the exact same thing..can you guys suggests some good lift kits to go with? budget for the kit is $1200 max and id like to get a net set of tires also..not sure on the size of the ones in the pic but im sure they will run me minimum $1500+
Sorry, but you wont find a quality kit for $1,200 fo you suv. Your year suv has rear coil springs so if you dont want to have a rough ride or the rear springs sagging in about a year save your money alittle longer and buy a good quality kit. We always used Rancho or Skyjacker because there springs rode well and lasted ( no sagging). In the eight years I worked at a truck customizing shop we only had to warranty one Skyjacker spring and it was off a abused mud truck. Do yourself a favor and take your time.
im sure you can find a local shop that might have a kit for your truck and with times right now its possible. after i installed my level kit we had a big boys toy show here and one of the local places had a kit for my truck for about what your looking to spend but at time i already sunk money into the level kit so i passed on deal. keep hunting youll find what your looking for.
I don't have any advice on lift kits, but I just wanted to say that is one bad freakin Yukon!!! I would want mine to look like that too if I had one!
Matt
Hallsville, TX
2005 Silverado 1500 LS Crew Cab 5.3L 2WD
K&N FIPK II
Magnaflow Exhaust
Hypertech Max Energy Programmer
Suspension Leveling Kit
Putco Element Window Visors
Carriage Works Billet Grille
TruXedo TruXport Tonneau Cover
i saw everyone say how good rough country was and the kit for my truck cost $1200 so i thought that would be my budget for the lift..but im by no means limited to 1200 i want to make sure i do it right the first time i dont like to half ass anything..this wont be for off road just city driving..i just really like the look..so if you guys can suggest a good kit that will set me up right and be comfortable to drive which is very important to me i would appreciate it..thank you
I would recommend the rough country kit. they are quality and will save you money. however, replace the shocks cuz the ones they give you are not that good. I would recommend getting a set of bilstein shocks like the 5100 or 5150. if you wanna spend a little more go with skyjacker or fabtech lifts.
PETE
95 GMC Sierra 2500
3" Body Lift, 33" Goodyear MTR's
5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
Sold :(
1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
Contact this GMTC Moderator for any problems or questions you may have
Join the GMTC Facebook Group!!! Join Here
I found a Rancho 4" lift for the 2002 Yukon, and it will run you $1,700 minus the shocks. ($400 est. for shocks)
I also found a Skyjacker 6" lift kit for $$1,900 minus the shocks again!
The main difference I can see is that the Rancho kit uses a spacer for the rear, and a coil spring for the front. And the Skyjacker kit uses the differential cradle for the front, and coil springs for the rear.
For the $200 difference I think I would go with the extra 2" inches, and get the skyjacker kit. Hope this helps you out a little........AMY BTW: the red kit is the Rancho lift kit.
http://www.gmtruckclub.com/forum/att...1&d=1236566776
Bookmarks
