Results 1 to 6 of 6
    Newbie One Bad Chevy is a glorious beacon of light
    Mar 2009
    Northeast ohio
    Default Timing Issue
    My 93 chevy has the 350 with a mild cam. It won't run right at tdc. Ive been told to set it at 6 BTDC, it runs better but no power at high rpm. I put a timing light on it and watched the automatic advance as i revved it, and noticed that it actually retards the engine as it revs up. Anyone know a possible reason/solution for this problem.
    Sr. Apprentice b8k2jha is a glorious beacon of light
    Dec 2008
    Enfield NH.
    What does it retard it to?? What type of ignition sytem?
    Grummet,
    02 Z-71 5.3
    03 Trailblazer
    84 Z-28 5.7, flat top pistons,Performer cam/intake,pacesettter headers Accel ign.,2100rpm stall converter..............
    97 S-10 Blazer 4.3 4x4 with solid axles and 8 inches of lift, not finished yet.
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Does it have a vacuum line? If so disconnect it and you won't see it retard the timing as you rev it up. What happens is the full manifold vacuum has it advanced at idle. When you rei it up the vacuum drops to zero and the timing retards.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Mar 2009
    Northeast ohio
    I have it set at 8 BTDC with ignition bypass disconnected. When the wire is connected it looks like the timing jumps to 20 or 25 BTDC, and when revved it moves closer to TDC. It is all electronically controlled.
  5. #5
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    Is the engine knocking? Are there any vacuum leaks? What do the plugs look like? Just some thoughts.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
  6. #6
    Legend bry2500 is a glorious beacon of light
    Oct 2008
    Gloucester, MA
    If you have any knock at all the knock sensor will retard your timing. Even a noisy lifter could trigger it. 2 things to try. Try high octane gas 93+ octane and/or unplug the knock sensor and see if it relieves the problem.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
Similar Threads
  1. When the timing is right....
    By Uncle Matt in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 05-06-2010, 08:28 PM
  2. Replies: 2
    Last Post: 03-28-2010, 11:15 PM
  3. timing off
    By dkseals8 in forum General Chevy Tech Q&A
    Last Post: 05-22-2009, 10:49 PM
  4. Help please! 454 timing issue
    By ratchet916 in forum Powertrain
    Last Post: 05-01-2009, 07:48 PM
  5. Timing
    By jasontay in forum General Chevy Tech Q&A
    Last Post: 05-18-2008, 06:08 PM
