    Default AMSOIL Ea Air Filters
    AMSOIL Ea Air Filters (EaA)
    The Absolute Best Air Filtration Available for Cars and
    Light Trucks.
    Guaranteed for 4 Years or 100,000 miles
    See Pricing Information or Place an Order
    Find the Filter That Fits Your Vehicle
    Master Filter Cross Reference Guide
    AMSOIL Ea Air Filters represent a major breakthrough in filtration technology. The revolutionary nanofiber technology used in AMSOIL Ea Filters captures more dirt, holds more dirt and allows better air flow than conventional air filters. AMSOIL Ea Filters improve engine performance and help engines last longer.
    Absolute Efficiency
    AMSOIL Ea Air Filters are the most efficient filters available to the car/light truck market. Ea Air Filters’ synthetic nanofiber media removes 5 times more dust than traditional cellulose filter media alone and 50 times more dust than wet gauze filter media. AMSOIL Ea Air Filters have a service life of 100,000 miles or four years, whichever comes first.
    Better Air Flow
    AMSOIL Ea Air Filters allow more airflow than filters that use cellulose media alone. Cellulose fibers are larger than nanofibers, and have larger spaces between the fibers, causing contaminants to load in the depth of the media and plug the airflow path, which results in higher restriction and less capacity. The synthetic nanofibers in EaA Filter media have submicron diameters and small interfiber spaces, which result in more contaminants being captured on the surface of the media and lower restriction.
    More Capacity
    AMSOIL Ea Air Filters hold up to two and a half times more contaminants than cellulose air filters. Since the nanofibers in the media are so small there are more pores per square inch, allowing for higher dirt-holding capacity and lower pressure drop when compared to cellulose filter media alone. Thinner media fibers produce more uniform pore size distribution, improving the filter’s overall quality and ability to capture and retain particles. Testing shows that Ea Air Filters hold 15 times more contaminants than a wet gauze type filter.
    Cleanable - Longer Life
    When cleaned according to AMSOIL specifications and used in normal service, AMSOIL Ea Air Filters are guaranteed for 100,000 miles or four years, whichever comes first. EaA Filters remain effective for 25,000 miles or one year before requiring cleaning. This coincides with the AMSOIL 25,000-mile/one-year motor oil drain interval, adding even more convenience for motorists by consolidating routine maintenance. (See below for cleaning instructions.)
    Applications
    AMSOIL Ea Air Filters provide superior air filtration for vehicles in the auto/light truck market.
    Cleaning
    EaA filters should be cleaned every year or 25,000 miles, whichever comes first. Carefully remove the filter from the housing. Clean the housing with a shop towel, being careful not to knock contaminants into the air inlet. Filters can be cleaned by carefully vacuuming the filter media on the dirty side, or by holding the filter with one hand and carefully blowing the filter media at a 45 degree angle on the clean side using low-pressure shop air (15-20 lbs. psi).
    Service Life
    AMSOIL Ea Air Filters are guaranteed for four years or 100,000 miles, whichever comes first. The guarantee applies only if the filter has been serviced according to AMSOIL recommendations. In off-road, frequently dusty or other severe duty applications, clean and change more often as determined by operating conditions or as indicated by restriction gauge.
    AMSOIL Warranty
    AMSOIL warrants that its filtration products are fit for use according to AMSOIL’s recommendations and warrants its products to be free of defective materials, design and workmanship.
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Order online:
    Default Preferred Customers Save Up To 25% Across The Board On ALL Amsoil Products.
    To order
    Light Trucks.
    Click Here
    Scott Douglass
    248-721-1002
    contact me
    Order online:
    Default Look up guide.
    Use the AMSOIL application look up guide to find the right filter for your truck by clicking here.
    Order online:
    Contact me for special pricing during the GMTC Summer Contest on AMSOIL Ea Air Filters and all other AMSOIL products.
    Also check out the Injen intake systems by clicking here.
    Order online:
    Jr. Engineer Falcone's Avatar
    Apr 2009
    Toronto, Canada
    I wanted to do replace my stock filter with a higherflowing unit to get the most out of my engine as I could on a budget. So I asked Scott (1st Synthetics) So ship me one of the AMSOIL Ea air filter because I had been disapointed in the K&N one I purchessed for my other vehical.
    Scott was kind enough to hook me up and get me one of the Ea filters very quickly and for an amazing price, $25 less then the K&N AND that's including shipping! Once I put the filter in I noticed an instant improvement in just even the basic running of my engine all boost to all aspects of its performance. Before I hardely had any pickup in 5th at highway sppeds, now I don't need to downshift to pass people anymore, the Ea flows so much more air then my previous filter it just blows me away.
    Everyone should check these filters out they blow K&N away and are a much better value.
    2010 Sierra Nevada Edition
    4.8L Ext. cab - Black Z85 4x4 G80
    Shaved a couple badges and 4x4 stickers, DeeZee Red label Low Pro gloss black Brite plate cross box,DeeZee gloss black Brite plate bed rail caps , K&N,more to come.
  1. K&N filters Discussion - Do they work?
    By Montana in forum GM Powertrain
    Last Post: 01-17-2011, 02:50 PM
  2. green air filters
    By wolfrivercc in forum Performance & Fuel
    Last Post: 06-10-2009, 09:11 AM
  3. Those of you with K&N filters
    By MWright936 in forum Performance & Fuel
    Last Post: 01-23-2009, 08:28 AM
  4. Suv Filters
    By hbhat3 in forum Chevy SUV & Crossover Tech Forum
    Last Post: 12-10-2007, 08:59 AM
  5. Cab Filters
    By cascman in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-24-2006, 08:37 PM
