Results 1 to 7 of 7
    Jr. Apprentice capcan is a glorious beacon of light
    Mar 2009
    Seymour, TN
    Default 2001 Pontiac Sunfire timing question
    Ok, I know it's not a truck or a Chevy, but it is a GM and I understand it is a Chevy engine, so here goes. My wife drives a 2001 Pontiac Sunfire with the small 2.2 engine. It has 130,000 miles and runs great, but I'm concerned. I keep getting conflicting answers concerning the the timing chain. As I said, it runs great and doesn't make any nosies, but I need to know if I'm supposed to change the timing chain or not. Some have told me to change it at every 100,000 miles (I didn't) and some have told me not to touch it untill it starts making nosies or goes bad. I just went to a local shop yesterday (not a GM dealer) and asked them and again I was told not mess with it until I need to. What shall I do?? Please advise!!
    Capcan - Seymour, TN
    1999 Chevy Suburban C2500 2wd 3/4 ton 454 BB 225,000 miles
    2001 Pontiac Sunfire 2.2 engine 169,000 miles
    1994 Ford F150 4.9 engine 160,000 miles
    Jr. Engineer mjalstad is a glorious beacon of light
    Jan 2009
    Rochester, MN
    Timing chains are considered a lifetime part. It would be pretty rare for it to break and it's something you should probably just leave alone. If it were a timing belt, you would probably want to change it at the specified interval such as 50K or 100K, but replacing a chain would kind of be like replacing your valve springs, there is no reason to do it unless it fails.
    99 Silverado Z71 4.8
    2" Suspension lift (Add-a-leafs and leveling keys)
    Long tube headers with 3" offroad Y-Pipe
    Volant Cold Air Intake with Ram Air Intake Tube
    Jet Mass Air Flow Sensor
    Diablosport Predator Tuner
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
    35" Yokohama M/T's
    K&N Intake
    Airraid Throttle Body Spacer
    Hypertech Programmer
    Dual Flowmasters
    Jr. Mechanic jlsparky7 is a glorious beacon of light
    Jan 2009
    As mentioned earlier timing chains do not need to be changed, however it probabl has a timing belt. Most 4 cylinders have timing belts. It is just a matter of time before it breaks. Most manufacturers reccomend changing the timing belt between 60,000-100,000 miles. If I were you id change it and have the peice of mind. Better than having a stranded wife.
    My girlfriends timing belt just broke on her 2001 escort at 138,000 miles.
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    im 99% sure that car has a timing belt, should be replaced every 60k miles. you do not want that to break you can do a lot of damage to the motor if it does, my wife's old car (95 neon) broke the timing belt and rosted the head broke some bent some valves damaged the pistons and so on.
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
  5. #5
    Jan 2009
    Rochester, MN
    Quote Originally Posted by Z71_guy View Post
    I'm 99.9% sure that car has a chain.
    Also, you are only going to damage a motor by breaking the belt if it is an interference motor. I believe that the piston in interference motors comes up as high as where the valves are when they are open so if they are open and the piston comes up it will damage the valves and pistons. If it is a non-interference motor which I think is more common among domestic vehicles, you aren't going to do anything.
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    35" Yokohama M/T's
    K&N Intake
    Dual Flowmasters
  6. #6
    Feb 2009
    Minnesota
    Quote Originally Posted by mjalstad View Post
    i forgot about the interference aspect of that, whoops my bad on the belt its a chain,
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
  7. #7
    Mar 2009
    Seymour, TN
    Default Sunfire timing chain
    OK, I'm still not sure one way or the other, but it sounds like most agree, that it is a chain, and I should leave it alone UNLESS, so that's what I'm going to do. Thanks for the info.
Similar Threads
  1. 82 K10 - 350 5.7L - Timing Question
    By ahobson1 in forum General Chevy Tech Q&A
    Last Post: 07-03-2010, 08:44 AM
  2. 2001-2005 chevy cavalier & sunfire remote keyless entry
    By Steve in forum Chevy Keyless Entry Remotes
    Last Post: 07-25-2009, 01:10 AM
  3. 2001-2005 chevy cavalier & sunfire remote keyless entry
    Last Post: 07-23-2009, 12:51 AM
  4. '98 Pontiac sunfire sending unit ~ opinions
    By TrailLeadr in forum General Chevy Tech Q&A
    Last Post: 04-24-2009, 09:28 AM
  5. 2005 Pontiac Sunfire
    By Cableguy in forum Other GM Cars
    Last Post: 06-17-2007, 06:28 PM
