GM Truck Club
Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
  1. #21
    Quote Originally Posted by mphazen View Post
    I am at 5000 miles on Mobile 1 Fully Synthetic and my change oil light is starting to come on. I think it is not due to the oil quality but based on miles (how the computer registers). From what I remember, resetting the computer simply is to pump the gas pedal three times before starting the engine (with the ignition on).
    I was thinking of stretching to 7,000 miles on the oil change... should I reset the computer or change the oil?
    2002 Chevy Silverado Z71 4x4 Ext. Cab 5.3L @ 105,000 miles.
    The Best Truck I've Ever Had!!
    I would not recommend running M1 past the 7K mile mark without sending it in for oil analysis.
    If you do this it will be a tell tail sign on how long you can run your next oil change. M1 is not designed to go more than 7K miles to my knowledge this is why I recommend not doing so. Only go as long as the manufacture of the oil recommends.Iif you want extended drain interval up to and over 25K miles use AMSOIL.
    2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
    AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
    Preferred Customers Save up to 30% Click here!!!
    Executive Direct Jobber ZO# 1695636
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
  2. #22
    Jr. Mechanic
    Apr 2008
    Lexington, SC
    How much does the amsoil for my 2500 diesel run a quart? I know that there is a 15k and 25k amsoil but how much does it go for? I think someone told me that it take 10qts to fill it back up. Are the oil filters expensive?
    2003 Avalanche 4x4 with cladding 110k miles +, K&N stock replacement air filter, Skyjacker 8000 shocks, Hawks LTS pads, Summit Racing brand drilled and sloted rotors, Sylvania ZXE high & low beams, leveling kit, 285/70/r17 Michelin M/S
  3. #23
    I Change every 3K miles with Mobil1 Sythentic 10W-30. Im thinking of starting to go to 5K but I change every 3 just so i know everythings good in the engine
    2000 Chevy Silverado 1500 5.3L Z71 - 4x4
  4. #24
    Legend kgibson181's Avatar
    Jul 2009
    Cedar Grove, NC
    Every 3 to five thousand miles oil and filter for me. My dad got me trained on that cycle, and since I'm 16 with a bad paying job he pays for the oil and filter as long as I change it.
    2003 Silverado 1500
    V8 4.8L 294ci
    2 inch Pro Comp Leveling Kit
    3 inch Rough Country Lift
    33 inch Nitto Terra Grapplers
    5% Tint All Around
    2 12" Kenwoods
  5. #25
    I shoot for 2500 miles. Valvoline MaxLife synthetic blend 5W-30. Just switched to WIX filters. I bought the truck with 75K, now has 135K. Bought Tahoe with 145K, now has 175K. Neither engine makes a peep, and both start burning oil after 3K.
Similar Threads
  1. Oil Change at Texas Oil x Change
    By Steve in forum Chevy Compact Cars (Aveo & Cobalt)
    Last Post: 06-11-2010, 03:30 PM
  2. Diesel Service Intervals
    By parkermt1 in forum GM Diesel & DuraMax
    Last Post: 12-18-2009, 09:40 AM
  3. 09 5.3 First Oil Change
    By jimmys5600 in forum General Chevy & GM Tech Questions
    Last Post: 10-06-2009, 09:52 PM
  4. oil change
    By glp08 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-20-2008, 04:51 PM
  5. Oil Change Intervals [Expired Topic]
    By Steve in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-07-2007, 03:20 PM
