Results 1 to 10 of 10
    Sr. Apprentice scrapeincali is a glorious beacon of light
    Mar 2009
    santarosa california
    Default wheel spacers and adapters?
    i got 16" boyds for my truck after having 20"s and ran into a problem, the back lip of the rim hits the lower control arm when i turn the wheels because there 2" drop spindles and they hold the bottom of the rim way up hugging the lca so i tried 3/8spacers and its not enoughf space so now im thinking of 1"adapters because the rims have ford pattern and chevy pattern (my truck is a chevy 75) or getting half inch spacers on top of the 3/8s i already got and adding longer wheel studs and is any of that safe? i used spacers before but i only had that for like 4 months and sold it
    trucks got 5k invested only needs paint trade for bagged s10 82+
    350 10:1 summit rebuild kit, double roller,5speed camaro,10bolt 3:42 posi,cnotch xpipe flowmasters, roll pan, sounds nice and loud real lobey, dont know what kind of cam is in it got around 5k on everything
    new interior all black ,headliner,carpet b&m short shifter and its a 75 with 82 body dual tanks
    Mar 2009
    and i just cant turn all the way but when i ride right now i got 5 1/2 turns on the lug nut and my truck for some reason skips across the road when turning semi hard (i just test road it one time i live in the boonies) so i dont know whas going on rides like crap
    Attached Thumbnails Attached Thumbnails Click image for larger version
    Legend
    Pete95Sierra is a name known to all
    Jan 2008
    Morristown, NJ
    i would look into some spidertrax 1.5" wheel spacers/adapters.
    PETE
    95 GMC Sierra 2500
    3" Body Lift, 33" Goodyear MTR's
    5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
    Sold :(
    1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
    2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
    Contact this GMTC Moderator for any problems or questions you may have
    Join the GMTC Facebook Group!!! Join Here
    Sr. Engineer sheep is a glorious beacon of light
    Apr 2008
    Ogden, UT
    i wouldnt recommend doing spacers on top of spacers even if you make the studs longer i agree with pete do some 1.5 bolt on adapters can get them on ebay and i believe from off road shops, i know we can order them at discount but it depends on what manager you talk to and if he is willing to order them for you, once you get them on either take it to a tire shop or do it yourself but after 75-100miles take the wheels back off and retorque the spacers down to spec.
  5. #5
    Mar 2009
    I just got some 1" spacers for free and im looking to get 1" longer studs .. Should i just go with wheel adapters.. Also if i put space in the front should i do the back or does it matter, cause there wider in the back then the front anyway
  6. #6
    Mar 2009
    if anybody has any experienc id like to hear it cause i dont trust spacers personally but im stuck with doin it
  7. #7
    Legend
    Jan 2008
    Morristown, NJ
    i know a lot of guys that use them on their jeeps and they dont have any problems with them. just go back and check them periodically to make sure they do not come lose
    PETE
    95 GMC Sierra 2500
    Sold :(
  8. #8
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    Like Pete said they're popular on Jeeps and have little problems.
    I use set of 3/4" on my Wrangler to clear the eliptic springs during full articulation, no problems with them as long as I pay attention to the torque.
    I had a set on a early 90's GM that kept giving me issues with rear seals but a later teardown of the axle revealed a warped housing and I now think that might have been the real culprit.
    I'd avoid spacers that use through studs and use only the style that has studs mounted into them, the through stud style makes you use longer studs and with stretching of the studs they loosen up faster and cause more headaches.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
  9. #9
    Jr. Mechanic hunky is a glorious beacon of light
    Mar 2008
    I have used spacers alot on my various vehicles with no problems at all. Just make sure the lug nuts match the spacers and wheels (they may have a different taper and/or depth).
  10. #10
    Mar 2009
    shoot thanks alot.. i am having a hard time finding longer studs for my truck and i probably only need a half in or so but i just got 1" spacers for free there actually adapters i knocked the studs out of but i think since i cant find any studs im gona go any buy the billet aluminum 1" spacers/adapters that have there own lug studs like you guys are recommending, and just putthem on all four tires so it looks descent ... thanks alot for your guyses responce when i needed it and im always willing to hear anymore experiences so dont hold back any stories or anything
Similar Threads
  1. Looking For Wheel Spacers.
    By RSMark5 in forum Lifted & Offroad Suspension
    Last Post: 03-21-2010, 07:12 PM
  2. wheel adapters
    By Timmy6216 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 12-13-2009, 01:14 PM
  3. wheel spacers
    By shaggyiroc in forum Lifted & Offroad Suspension
    Last Post: 12-07-2009, 07:37 AM
  4. wheel spacers
    By kentkmm in forum General Chevy Tech Q&A
    Last Post: 08-21-2009, 12:25 AM
  5. wheel spacers
    By countryboy73703 in forum Lifted & Offroad Suspension
    Last Post: 07-25-2009, 06:42 PM
