Results 1 to 6 of 6
    Jr. Apprentice Tiny1987 is a glorious beacon of light
    Feb 2009
    Alberta
    Default 4WD Problems need help please.
    ok 2004 chev silverado crew cab 1500. have noticed that when either auto 4wd or just 4wd is turned on there is a kind of howl noise in the front end when slowing to a stop. but when in 2wd it sounds fine. even switching from 4wd to 2wd while it is making the noise makes it go away. also when in auto 4wd and service 4wd light comes on it will not make the noise. could the encoder motor be causing this or could it maybe be some water intrusion on some wires? i could really use any input on this one please. i have checked for codes in the transfer case and only find a history code which i think is c0374 which they call just a generic malfunction. thanks for any input.
    Legend
    silveradotrailblazer has a reputation beyond repute
    Dec 2008
    Andalusia,Alabama
    Cool 4wd problems ned help please
    Ive never experianced that with my 05, but I heard that if you are on a hard surface in 4wd the front makes ,as discribe to me a rumble noise.
    Feb 2009
    Alberta
    this sounds about the same as a bad wheel bearing at highway speeds.
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Quote Originally Posted by Tiny1987 View Post
    The very first thing to do is check the oil in the differential. The axle seals can leak and I have seen these diffs run dry. If the oil's OK you may have a bad U Joint. Best bet is to get it up on a hoist and run it in the air so you can find the problem.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  5. #5
    Master Mechanic CarpenterGuy is a glorious beacon of light
    Jul 2008
    Leeds, Alabama
    i've experienced the same noise. i thought it was normal though. what does auto 4wd do? does it swap between 4 and 2wd?
    2006 Silverado Z71 - 97,000 - totaled, RIP
    2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
    I'll keep my money, guns, and freedom. You keep the Change.
  6. #6
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    auto 4wd engages the front axles when it senses slip in the rear wheels,
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
Similar Threads
  1. S10 ZR2 4x4 problems
    By footballmn in forum Powertrain
    Last Post: 01-21-2010, 09:35 AM
  2. 4wd problems
    By NewfZ71 in forum Powertrain
    Last Post: 01-11-2010, 11:35 AM
  3. 4wd problems.
    By 95Chevyk1500 in forum Powertrain
    Last Post: 12-10-2009, 02:05 PM
  4. Chevy Silverado Heater problems blower problems
    By bidutch in forum Powertrain
    Last Post: 12-13-2007, 06:59 PM
  5. Got a few problems
    By 95chevyguy in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-16-2007, 01:03 PM
