Results 1 to 2 of 2
    Sr. Apprentice otis24 is a glorious beacon of light
    Mar 2008
    Default 4x4 Posi-lok question
    I have a question regarding the 4x4 Posi-lok system. I understand that this basically replaces the actuator to lock the front axle. If my encoder motor is bad, does this system benefit me any? Will I still need to replace the encoder motor if I install the 4x4 Posi-lok? This is on a 1998 GMC Jimmy.
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    It's been a while since I've looked at it, but, if memory serves, the 4x4 posi-lock only replaces the center axle disconnect on the front diff. The encoder motor is on the transfer case. Some people prefer the posi-lock (cable operated, isn't it?) because they feel it is more reliable. It seem much more reliable than the earlier "thermoelectric" CAD's that GM used, but the CAD on your '98 should be a simple electric motor. I'm not convinced the posi-lock is significantly more reliable than what you have.
    And, of course, replacing the CAD isn't going to fix anything if the problem is with the motor on the transfer case.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
Similar Threads
  1. posi??????
    By k/4x4/93 in forum General Chevy Tech Q&A
    Last Post: 05-25-2010, 10:53 AM
  2. Posi Track
    By 02z71 in forum General Chevy Tech Q&A
    Last Post: 11-26-2009, 11:38 AM
  3. Need Posi Track...
    By V8_singlecab_ss in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 08-22-2009, 07:55 AM
  4. Posi??
    By mrcaddy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-04-2009, 07:09 AM
  5. Posi anyone?
    By tlperry68 in forum Powertrain
    Last Post: 01-30-2009, 06:12 PM
