Results 1 to 5 of 5
    Newbie BoomerFF373 is a glorious beacon of light
    Mar 2009
    Upstate NY
    Default 2000 S-10Transmission fluid level
    Anybody know the fluid capacity of a 4L60E with the deep stepped bottom pan ? The repair manual says 5 quarts but I'm thinking that's for the shallow pan.
    Legend 1st Synthetics is a name known to all
    Feb 2009
    Nationwide
    Quote Originally Posted by BoomerFF373 View Post
    Automatic Transmission, 4L60-E Initial Fill..........5.0 quarts
    Automatic Transmission, Total Fill
    4 speed 4L60-E..........11.0 quarts
    2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
    AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
    Preferred Customers Save up to 30% Click here!!!
    Executive Direct Jobber ZO# 1695636
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Mar 2009
    Upstate NY
    Thanks for your reply!
    Feb 2009
    Nationwide
    Well here is all of your fluid capacitys.
    CAPACITIES
    Engine, with filter..........4.6 quarts[1]
    Cooling System, Initial Fill..........12.0 quarts
    AMSOIL Antifreeze and Engine Coolant
    Manual Transmission, NV1500..........5.7 pints
    Manual Transmission, NV3500..........4.2 pints
    Differential, with 7.25 ring gear Front..........2.5 pints
    Differential, with 8.25 ring gear Front..........4.2 pints
    Differential, with 9.25 ring gear Front..........5.9 pints
    Differential, with 8.6 ring gear Rear..........4.0 pints
    Transfer Case,NP207..........4.6 pints
    Transfer Case,NP231, NP233..........2.1 pints[2]
    Transfer Case,BW4472..........2.5 pints
    Transfer Case,NV231/233..........2.1 pints[2]
    Transfer Case,NV136/236/246..........4.0 pints
    Order online:
  5. #5
    Mar 2009
    Upstate NY
    Thanks! I do appreciate it!
Similar Threads
  1. ReadyLift - front level kit or SST lift/level kit
    By JW2007-6.0 in forum Lifted & Offroad Suspension
    Last Post: 03-13-2010, 03:07 AM
  2. Transmission Fluid level issue
    By i_build in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-07-2009, 08:11 PM
  3. how do you check fluid level
    By bigbrett in forum Powertrain
    Last Post: 10-24-2007, 02:40 PM
  4. muncie fluid level ?
    By bgc1976 in forum Powertrain
    Last Post: 07-06-2007, 10:41 PM
  5. on the level, really!!! Level headed?? HUH?? [Expired Topic]
    By army dude in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-25-2007, 11:02 PM
