    Question 95 Yukon GT blower motor replacement question
    I have a bad heater blower motor and have purchased a new one. Has anyone pulled one of
    these out and if so what are the steps? I have looked at it and can't determine if it somes
    out through the glove box opening or downward.
    Thanks
    TauniGT
    I don't know if your dash is like the 94's or the 96's, but on the 96, you have to remove a rubber cover on the blower motor, remove the screws that hold the motor in place, disconnect the power and pull it out from under the dash. It is a very easy swap.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    When I removed the dashboard on my '95 Suburban (whilst replacing the evaporator and heater core...), it was very easy to replace the blower motor. But, that was an exceptional case.
    According to GM, you need to remove the glove-box, the plastic trim covering the footwell/door-hinge area, and the bolt holding the right side of the instrument panel. Removing that bolt allows you to pry back the instrument panel a bit to squeeze out the old blower motor/fan assembly. Of course, there are a few wires and even the ECM to unplug and remove. It's not a straight shot - there's a bit of flexing and prying to squeeze the new motor into place. And it comes back and down, under the instrument panel. Removing the glove-box is only needed to get access to the wires, ECM and mounting screws.
    It's surprisingly difficult given how seemingly accessible the blower motor is. But hey, it's easier than my '68 Buick Skylark - I had to remove the right-front fender to replace that blower motor.
    Kirk
    Norwalk, CT
  1. Blower motor replacement 93 Suburban
    By unplugged in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 12-21-2010, 01:53 PM
  2. Blower Motor
    By TheShamrock7 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 05-12-2010, 11:15 AM
  3. Chevy Silverado Blower Motor Replacement
    By BEEMAN in forum General Chevy & GM Tech Questions
    Last: 02-21-2010, 07:37 PM
  4. Blower motor
    By jb9164 in forum General Chevy & GM Tech Questions
    Last: 02-24-2009, 07:37 PM
  5. yukon blower motor
    By rod in forum General Chevy & GM Tech Questions
    Last: 03-13-2008, 07:20 AM
