GM Truck Club
Page 2 of 3 FirstFirst 123 Last Post byLast Post by
Results 11 to 20 of 21
  1. #11
    well thanks for the heads up guys.... i should be taking it in soon
  2. #12
    Sr. Apprentice lube70's Avatar
    Jan 2009
    Northern NJ
    Default same
    I had the same issue happen to me in my 06 Silverado. Only came up for a second and then went off. Called ONSTAR and they ran a diagnostics on the air bag system, NOTHING!!!
    Then went to GM and had them run the codes, NOTHING...They say that the battery voltage being low (a battery going bad) can cause this. Have not had the light since. Getting a new battery for the truck since its already going on 3 years old and GM's batterys are not that good on lasting.
    Good luck on your gremlin!!!
    Don
    2006 Chevy Silverado crew cab 1500
  3. #13
    thats funny u said that because my truck had a bad bettery and i had just changed it like two weeks before
  4. #14
    Im in the same boat! I used my buddies scanner and came up with a B0103 code which says is the front right crash sensor so is there a way I can test the sensor to see if its faulty?
  5. #15
    Sr. Apprentice msvx95's Avatar
    Sep 2009
    Mentor, Ohio
    I just replaced all sensors and parts on my 95 subaru with airbag problems...I let the dealership look at it years ago and they couldn't find the problem, but after 5 hours still billed me. This year I decided to do it myself. I ended up finding a short in my main harness wiring.
    If you can get to the other end of the sensor where it plugs into the airbag computer ( I assume most airbag units are similar), then test the resistance of the sensor. You may need a factory service manual to tell you what readings the sensor should fall within.
    Matt
  6. #16
    Can I just disconnect the sensor off the wire and check the resistance?
  7. #17
    Sep 2009
    Mentor, Ohio
    Well I haven't looked at the sensors on our vehicles, but if you can disconnect it, then yes check the resistance, but disconnect the negative cable on the battery first and wait about 10 mins.
  8. #18
    The capacitor that fires the charge stays charged longer than 10 minutes.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  9. #19
    Sep 2009
    Mentor, Ohio
    ok so then let the vehicle sit overnight with the neg. cable disconnected. I'm also guessing you will be laying on the driver's or passengers floor area where the wires connect to the computer. Your head shouldn't be anywhere near the front of the steering wheel anyways...LOL
  10. #20
    Default !
    Also, around te same time as this started happening I noticed my seat controll button is backwards now! When I push it down, the seat bottom tilts up and vice versa! Any ideas on that?
Similar Threads
  1. airbag light
    By 2wheelmudder in forum GM Electrical Tech
    Last: 06-17-2010, 10:46 PM
  2. Airbag Light
    By ahm1127 in forum General Chevy & GM Tech Questions
    Last: 03-22-2010, 10:52 AM
  3. 03 silverado-SERVICE AIRBAG
    By buffalojoem in forum Chevy Silverado Forum (GMC Sierra)
    Last: 03-08-2010, 08:38 AM
  4. Service Airbag!
    By Kdogg05 in forum Audio, Video & Gadget Tech
    Last: 09-26-2009, 07:11 PM
  5. airbag check light
    By wookabay in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-19-2009, 07:23 AM
