    Default Retarded ignition??
    I have hooked up a ScanGage to my truck and the Ignition timing ranges from -15 to -24. Does this mean ATDC? Would this be a normal reading for a truck with an ECU? My old 85 used to be set slightly advanced at idle and would increase under acceleration.
    Boreal
    96 Chevy K1500 Silverado Shortbed 5.7L
    Jr. Engineer
    Rochester, MN
    I used to have a Grand Prix GTP and I was really into tuning. I think the 98 Grand prixs always read negative numbers for timing, so maybe yours is the same way. Your timing should decrease under acceleration or heavier loads and be high when cruising. My timing goes all the way up to around 50.
    99 Silverado Z71 4.8
    2" Suspension lift (Add-a-leafs and leveling keys)
    Long tube headers with 3" offroad Y-Pipe
    Volant Cold Air Intake with Ram Air Intake Tube
    Jet Mass Air Flow Sensor
    Diablosport Predator Tuner
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
    35" Yokohama M/T's
    K&N Intake
    Airraid Throttle Body Spacer
    Hypertech Programmer
    Dual Flowmasters
    Thanks for the info. Another question - is a reading of -28 equivalent to -28 degrees ATDC with a timing light?
    Quote Originally Posted by mjalstad View Post
    Boreal
  1. Problems with key in the ignition
    By rcrq500 in forum General Chevy & GM Tech Questions
    Last Post: 09-23-2009, 10:08 PM
  2. Ignition switch ?
    By brutin in forum Chevy C/K Truck Forum
    Last Post: 01-27-2009, 07:48 PM
  3. MSD Ignition??
    By thekingsphance in forum Performance & Fuel
    Last Post: 01-02-2009, 07:06 PM
  4. Ignition [Expired Topic]
    By AndyD in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 09-28-2006, 02:17 PM
  5. Ignition
    By Mirth in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 03-29-2006, 01:24 PM
