Page 1 of 2 12 LastLast
Results 1 to 10 of 14
    Sr. Apprentice Kdogg05 is a glorious beacon of light
    Jun 2008
    Canada
    Default Crank more or Keys?
    So I have on 05 Silverado 1500 z-71. I'm trying to stuff some 285/70 R17's under it and want to know if I should buy keys or just crank the bars till the bolts bottom out. Right now Theres about 8.5 mm of thread showing on them. Thanks for the help in advance.
    Jr. Mechanic yotchie is a glorious beacon of light
    Nov 2008
    saskatchewan
    personally id just go with buying the keys. fast fixes often seem ok but end up being more expensive somehow in the long run.
    Legend TrailLeadr has a reputation beyond reputeTrailLeadr has a reputation beyond repute
    Jun 2005
    Coventry, Rhode Island
    2 Post(s)
    1 Thread(s)
    Part of the problem with cranking is besides having a rough ride, it roasts the daylights out of your tires, if you don't follow through with a proper alignment.
    Keys really are your best bet.
    Patrick
    Rhode Island
    Jr. Engineer mjalstad is a glorious beacon of light
    Jan 2009
    Rochester, MN
    Quote Originally Posted by TrailLeadr View Post
    So if you crank your stock keys up and get an alignment it will wear your tires more than if you replace the keys and get an alignment?
    99 Silverado Z71 4.8
    2" Suspension lift (Add-a-leafs and leveling keys)
    Long tube headers with 3" offroad Y-Pipe
    Volant Cold Air Intake with Ram Air Intake Tube
    Jet Mass Air Flow Sensor
    Diablosport Predator Tuner
    Previous Truck:
    97 Suburban K1500
    3" Body lift
    2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
    35" Yokohama M/T's
    K&N Intake
    Airraid Throttle Body Spacer
    Hypertech Programmer
    Dual Flowmasters
  5. #5
    Jr. Mechanic ChevyFarmKid is a glorious beacon of light
    Mar 2008
    Chelsea, MI
    Default crank
    you shouldn't have to do nothing to fit 285's on your truck. they will fit with no rubbing as long as you have stock rims, if you have aftermarket rims, cranking the torsion bars won't fix the rubbing, you will need key's.
  6. #6
    Jun 2005
    2 Post(s)
    1 Thread(s)
    Quote Originally Posted by mjalstad View Post
    No. Sorry, maybe I shouldn't have said it the way I did. Some people have the notion that cranking the keys will simply stiffen the ride, raise the front end and nothing more. But it throws the geometry off the front end off, so "DO" get an alignment if you do it.
    With new lift keys you shouldn't need to crank them, but you'd still need an alignment.
    Patrick
    Rhode Island
  7. #7
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Agreed with keys, AND with any changes an alignment to follow is a must!
    Darcy
    Washington State
  8. #8
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    get the new keys and make sure to get it aligned
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
  9. #9
    Newbie johnny_ringo is a glorious beacon of light
    Mar 2009
    the South
    forgive my ignorance, but i'm still figuring out this forum stuff and couldn't get a new thread going. i have a similar question about my truck (2004 silverado 1500/4wd). how do i tell if my truck (bought used) has aftermarket keys or if it's just been cranked on?
  10. #10
    Legend tlperry68 is a glorious beacon of light
    Oct 2008
    Huntington Beach, CA
    I tried what the torsion bar adjustment was like and it sucked. I had the ProComp level lift kit installed at it was great. They put on shock extenders and all.
    Trevor - Huntington Beach, CA
    2007 GMC 2500 4X4
Similar Threads
  1. keys
    By 2wheelmudder in forum Audio / Video Electrical
    Last Post: 06-16-2010, 01:52 AM
  2. lift keys...Green keys??
    By bwoodmiles in forum General Chevy Tech Q&A
    Last Post: 03-24-2010, 12:31 AM
  3. crank TB
    By RussellFidel in forum General Chevy Tech Q&A
    Last Post: 10-30-2009, 04:37 PM
  4. Torsion keys
    By chevyman5.3L in forum Lifted & Offroad Suspension
    Last Post: 08-26-2009, 11:00 PM
  5. Are 99 sub keys chipped?
    By 99blueburb in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-02-2009, 09:48 AM
