Hi all. Just registered today and this is my first post. Looks like there is some good information on this site and some knowledgeable, helpful people. hopefully I can learn a few things and maybe help some others. The rotors on my 98 Z71 extended cab 4X4 need replaced. I picked some up at NAPA and thought I woudl try and do this myself. I've replaced brake pads but never had to do the rotors. Is this a difficult job? Any tips?
thanks,
Scott
if you can change the pads theres nothin to doin rotors.
I own a 2007 Silverado 1500 Crew Cab (new body style). my truck is Red and has the 4.8, basically stock but i got big plans.
just wash them off with dish soap or use brake clean to get the oil and metal shavings from manufacturing off
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
Is it absolutely necessary to replace the pads when replacing the rotors? If rotors are warped and vibrating during braking does that mean the pads are shot too? Thanks
Take them to a good shop and they can check the rotors, they may only need to be resurfaced saving you alot of money. Like someone said before make sure you clean the rotors before you put the pads on, any oil from your hand can make you rotors under perform.
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
you dont have to replace the pads when you change the rotors but it is recommended, if they are more than 50% worn then i would def replace the pads
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Thanks for the great advice. Very helpful if you've never done them before.
Took care of putting the new rotors on last night. cleaned them off with dish detergent as suggested. What a difference! No more teeth chattering vibration when coming to a stop. The pads looked good so I'm leaving them on for now. Planning an elk hunt in Colorado this fall and I'll be pulling a trailer up and over the Rockies so I'm thinking about resurfacing the warped rotors and throwing them on before the trip. The trip last fall killed them originally as the one guy rode the brakes pretty hard while I was sleeping in the back!!
Bookmarks
