I have a 1997 pick up and the back brakes don't work. When I try to bleed the brakes I sometimes get fluid to one wheel (driver's side) but never to the other on the rear. Front brakes work fine! Can somone help?
Check the brake lines for any pinch's or obstructions, then look at the brake bypass valve.
You might need to remove the bypass valve and bench test it.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
How do you test this bypass valve?
Ct9a- I cannot get fluid to the passenger side at all on the rear and not all the tim to the driver's side rear. Are these bypass valves a part I can just replace?
When you open the bleeder on the rear, does your assistant notice that the pedal goes down?
99 Silverado Z71 4.8
2" Suspension lift (Add-a-leafs and leveling keys)
Long tube headers with 3" offroad Y-Pipe
Volant Cold Air Intake with Ram Air Intake Tube
Jet Mass Air Flow Sensor
Diablosport Predator Tuner
Previous Truck:
97 Suburban K1500
3" Body lift
2" Suspension Lift (Add-a-leafs and cranked up torsion bars)
35" Yokohama M/T's
K&N Intake
Airraid Throttle Body Spacer
Hypertech Programmer
Dual Flowmasters
When the one on the drivers side worked which was not every time the pedal did go down and fluid came out of the bleed. But the passenger side never had any pressure at the bleed and the pedal did not go down. I checked it at the master cylinder and I did have pressure. Then I ran out of daylight.
I would probably try to remove the hose from the brake line on the passenger side while somebody is holding the pedal down. If the pedal moves, you know that your obstruction is in the hose, if it still doesn't, you can guess that it is probably the valve.
Previous Truck:
97 Suburban K1500
3" Body lift
35" Yokohama M/T's
K&N Intake
Dual Flowmasters
Does each individual brake line to each wheel have it's own valve?
I think that just the rear 2 share one valve. Not totally sure on that, I could be wrong.
Previous Truck:
97 Suburban K1500
3" Body lift
35" Yokohama M/T's
K&N Intake
Dual Flowmasters
Thanks for the help. I will tackle it again this weekend.
Bookmarks
