i want to put 3/4 ton leaf spring packs in my 97 tahoe to help with toe sag. is there anything i could cross reference with to get what i need? are they interchangeable with suburbans and silverados?
I know its not an answer to your question but have you looked at the Sensatrac Coil Over shocks?
I added them to by suburban to help with sag and they have worked great! Let me look for the post with the info on them
here they are
Monroe Shock/Strut - Rear
Part No. 58612
http://shop.advanceautoparts.com/web...GRPSHOCAMS____
The Monroe® Sensa-Trac® load adjusting shock absorber with PSD (position sensitive damping) and the Safe Tech™ system combines our exclusive precision tapered grooves in the pressure tube with application engineered valving and Fluon banded piston to improve the ride, handling, and safety characteristics of the vehicle.
These units also include a heavy gauge calibrated spring for extra control and comfort. A new pair of Monroe Sensa-Trac load adjusting shock absorbers can assist in maintaining ride height when up to 1,200 lbs*. of additional weight is loaded. These units are ideal for light trucks that carry varying loads or tow trailers.
add-a-leafs could help too, and might be less expensive
2006 Silverado Z71 - 97,000 - totaled, RIP
2006 Silverado Z71 - 70,000 (K&N 77 Series CAI, PowerAid TBS, Magnaflow dual rear exit, 33x12.50 Mickey Thompson MTZ, Tuff Country Torsion Keys, Tuff Country Add-A-Leafs)
I'll keep my money, guns, and freedom. You keep the Change.
i wouldnt go with the HD springs on a hoe, just get some new ones or the add a leaf system. with the heavier springs you are gonna get a harsh ride added to the short wheel base of the hoe
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
I would say go with an add a leaf as well. cheap and effective
PETE
95 GMC Sierra 2500
3" Body Lift, 33" Goodyear MTR's
5.7L 350 TBI Edelbrock SDT Exhaust, Flowtech Headers, K&N Intake
Sold :(
1999 Jeep Cherokee, 3" Rustys lift, 33" BFG MT's, locked, armored: Rolled :(
2000 Jeep Grand Cherokee Limited. K&N Intake, Custom Kolak Exhaust
Contact this GMTC Moderator for any problems or questions you may have
Join the GMTC Facebook Group!!! Join Here
Yep, I think those HD springs would make that backend bounce like a pogo stick that wouldnt even slow down for a good set of shocks.
Bags if ya got the money or a set of AAL's.
I saw a guy last week that bought the springs off a 2003 1500 for $25 and cut off the long spring to make it into a homemade AAL, dont know if I'd get that cheap, seems like the time expended getting everything together and the fab work would cost more than buying AAL's from a parts supplier.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
Add A Leaf and Level kit for those who might not know
i would look into the coil over shocks, putting them on my truck as soon as i can
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
Bookmarks
